Cisco Icon Library
dave.chadwick
Im looking for an upto date Cisco Icon library, that contains not only the older PPT icons but also the newer HW such as SD-WAN cEdge, ACI APIC, vEdge etc.  Although the icon-library-production-oct2016 library contains a very good quality image of ACI/Switches/FW's etc it lacks the newer icons as mentioned above.
Could you advise if there is a newer version of the icon-library-production-oct2016 file.
balaji.bandi
here is new all available here (stencils)
https://www.cisco.com/c/en/us/products/visio-stencil-listing.html
BB
dave.chadwick
BB, thanks for the prompt reply, these seem like physical product stencils rather than logical icons! Do you know if the same exists for the logical icons ?
not sure if this is what you looking, i have download long back dont remember the patch,
attached zip file check is this what you looking ?
BB
Hello BB,
I need to use these icons in my visio, do you have .vss version of it, or how to install those into visio, do you know?
BR,
Yogesh Gaikwad
