Cisco Router 899
allan.valverde
I am trying to connect and configure a Cisco Router 899, I need to know the exact Console cable model and/or type I need to buy , thanks.
Mark Malone
that's the new type with the USB end to connect direct to laptop and router without need for serial adapter
https://www.fruugo.ie/ftdi-usb-cisco-console-cable-usb-to-rj45-18m-6-ft-ftdi-chip/p-10947027-22858551?gclid=Cj0KEQjwmIrJBRCRmJ_x7KDo-9oBEiQAuUPKMqDlnbNflQqEFkRoiljdd90A5FthcanCuIfTmusIcWEaAuL08P8HAQ
These are the older ones you would need a serial adapter with this too though unless pc has serial port
http://www.elara.ie/productdetail.aspx?mancode=DB9CONCABL6&manufacturer=STARTECH.COM&gclid=Cj0KEQjwmIrJBRCRmJ_x7KDo-9oBEiQAuUPKMvN9cBZaOHnNNejG7LsjqMadsV6QDSOgdnJRJCq1JgMaAkAn8P8HAQ
Thanks a lot Mark Malone
