Missing Visio Stencils for Cisco 8000
kmccormick
I recently downloaded the Cisco 8000 Visio Stencils.
I noticed the equipment I was going to make a diagram of had missing MPAs and blanks.
The following MPAs were missing.
8K-MPA-18Z1D
The following MPA blanks were missing.
8K-MPA-BLANK
8608-MPA-BLANK
I also was needing stencils the following equipment that was missing.
8011-4G24Y4H-I
Can someone at Cisco please add these to the Cisco 8000 Visio Stencils?
Thank you.
balaji.bandi
Looks like module not released what ever available that in stencil url
https://www.cisco.com/c/en/us/products/visio-stencil-listing.html
BB
Yes the 8K-MPA-18Z1D is not released yet, so I do understand that maybe why it's missing from stencil file, but it's also mentioned in other documentation.
The 8011-4G24Y4H-I is released and is missing.
Additionally, when they make stencils adding the Blanks should be a requirement. Especially when the router in the stencil is shown with MPAs, line cards, fans, or power supplies installed rather than the Blanks. If the routers are not prepopulated with Blanks then there should be a requirement to provide the Blanks to cover unpopulated or wrongly populated areas.
