Recent Visio stencil file updates posted to cisco.com
Brett Newman
I thought it might be helpful to post an announcement of new Visio content that we have added in 2013.  The page URL is:
http://www.cisco.com/en/US/products/hw/prod_cat_visios.html
Cisco TelePresence (7 MB)
01/Jan/2013
Switches-Cisco Nexus 1000 (1 MB) New!
17/Apr/2013
Switches-Catalyst 4500 (5 MB)
06/Feb/2013
Security-Cisco ASA 55xx (7 MB)
06/May/2013
Routers-Cisco CRShttp://www.cisco.com/en/US/prod/assets/visio/Routers-Cisco_CRS_032511.zip.html (6 MB)
15/Apr/2013
Routers-Cisco ASR 9000 (3 MB)
14/Apr/2013
Routers - Cisco ASR 903 (3 MB)
13/Jan/2013
Brett Newman
Cisco Visio Production
Visimation Inc.
www.shapesource.com
16 Replies 16
Hi, are you able to find WS-X4724-SFP-E stencil? i unable to get it.
Thank you.
amadoriale
Great idea, though not upkept...
I don't frankly understand why not making a Module section for all SFPs related devices. As far as I remember they should be buried with some switches, but they are not so easily found - for instance atm I cannot find the 40gbps ones, nor the 10. I might just use the 1gbps for placement purpose, but unfortunately there doesn't seem to be an easy-to-read index either that could be consulted in order to find P/N and where the relative stencil is located.
It should be a little easier - if they are modules that work with specific devices, just include them inside of the package, so one opens that specific device and already can see all the compatible HW.
