Toll for check FCC ID
harisankarss1
Hi All,
Is there any tool available to check the FCC ID with the help of cisco part number ? Please help me.
My requirement is i need to check whether this unit/model is FCC certified or not with the help of Cisco Part Number.
cisco
The unit should have the FCC ID printed on it. If the device does not have wireless capability, it will not have an FCC ID.
If you cannot find the printed FCC ID label and you are sure the device has wireless capabilities, you can try searching for the FCC ID in google by doing the following search:
site:fccid.io Cisco MODELNUMBER
Good Luck!
