visio stencil for the ASA 5508-X
flavio.burattin
I need the visio stencil for the ASA 5508-X with FirePOWER with IPS, where can i download it?
i checked here: http://www.cisco.com/c/en/us/products/visio-stencil-listing.html
Security-Cisco ASA 55xx (ZIP - 7 MB)
06/May/2013
but unfortunately the 5508 model is missing, could  you send me the vss file?
tks,
F.
18 Replies 18
Sure, here it is in VSS.
Awesome! Thank you very much! Paul
7b.schappel
I'd like to submit this SVG for your use. I drew this up for a presentation using pieces of other Cisco stencils and various other SVG's. It contains 100% vector goodness. I hope you find it useful.
versu5K
Here you go
I just finished work on it.
There is a PSD source in the ZIP if you want to change something (model for example)
