Accessing node data properties from nodetooltip
Deniz AYDIN
Level 4
Level 4
I am tring to update selected node's properties like status,latitude and other some node data properties. For example upon on update method "
methods: {
// what happens when you hit 'Save' button
'update': function () {
$.ajax({
type: "POST",
url: "updateNode.php",
data: this.node().latitude,
success: function(return) {
console.log(return);
But I can not access the node properties other than label and id. Also is it possible to pass current node's data to the php as json object.
I found my fault, and corrected the code.
http://codepen.io/deniza/pen/NpvRvq
Deniz AYDIN
Level 4
Level 4
Hi I forked,
Standart tooltip for with custome values example to log custom value to console with button.
It gives an error of undefined object. If set method is removed from node it works fine. I tried several approach but I guess missing something.
Hi Deniz,
My apologies for no reply: looks like your post got lost in the shuffle. I'm glad you've found the resolution to all your concerns.
- Alex
