ASR9K VLL configuration failed to create/delete by netconf-yang
andryang
One of my telecom customer is trying to use netconf-yang to provision production system ASR9K, when they try following configuration, three problem met, may I have your support to check if ASR9K/IOS-XR support these configuration on yang model now?
Problem-1: does “service-policy” supported by YDK-API in IOS-XR 6.0.1?
Customer use YDK-Py sandbox to get VLL(VPWS) running configuration of ASR9K, the result is most of configuration could be successfully obtain except “service-policy input/output”, is it supported now?, if not, roadmap?
<ASR9K CLI command>
interface Bundle-Ether10001.100 l2transport
description "Leaseline_Number--10013--20M/5M"
encapsulation dot1q 100
rewrite ingress tag pop 1 symmetric
mtu 1580
bundle load-balancing hash auto
service-policy input eco-x
service-policy output eco-x
l2vpn
xconnect group eco
  p2p 10013
   neighbor ipv4 172.16.20.1 pw-id 10013
    pw-class control-word
YDK-Py polling result:
<YDK netconfservice.get_config>
<interface-configurations xmlns="http://cisco.com/ns/yang/Cisco-IOS-XR-ifmgr-cfg">
   <interface-configuration>
    <active>act</active>
    <interface-name>Bundle-Ether10001.100</interface-name>
    <interface-mode-non-physical>l2-transport</interface-mode-non-physical>
    <description>"Leaseline_Number--10013--20M/5M"</description>
    <ethernet-service xmlns="http://cisco.com/ns/yang/Cisco-IOS-XR-l2-eth-infra-cfg">
     <encapsulation>
      <outer-tag-type>match-dot1q</outer-tag-type>
      <outer-range1-low>100</outer-range1-low>
     </encapsulation>
     <rewrite>
      <rewrite-type>pop1</rewrite-type>
     </rewrite>
    </ethernet-service>
    <mtus>
     <mtu>
      <owner>sub_vlan</owner>
      <mtu>1580</mtu>
     </mtu>
    </mtus>
    <bundle xmlns="http://cisco.com/ns/yang/Cisco-IOS-XR-bundlemgr-cfg">
     <bundle-load-balancing>
      <hash-function>
       <hash-type>efp-auto</hash-type>
       <hash-value>1</hash-value>
      </hash-function>
     </bundle-load-balancing>
    </bundle>
   </interface-configuration>
  </interface-configurations>
  <l2vpn xmlns="http://cisco.com/ns/yang/Cisco-IOS-XR-l2vpn-cfg">
   <enable/>
   <database>
    <xconnect-groups>
     <xconnect-group>
      <name>eco</name>
      <p2p-xconnects>
       <p2p-xconnect>
        <name>10013</name>
        <attachment-circuits>
         <attachment-circuit>
          <name>Bundle-Ether10001.100</name>
          <enable/>
         </attachment-circuit>
        </attachment-circuits>
        <pseudowires>
         <pseudowire>
          <neighbor>
           <neighbor>172.16.20.1</neighbor>
           <class>control-word</class>
          </neighbor>
          <pseudowire-id>10013</pseudowire-id>
         </pseudowire>
        </pseudowires>
        <p2p-description>"Leaseline_Number--10013--20M/5M"</p2p-description>
       </p2p-xconnect>
      </p2p-xconnects>
     </xconnect-group>
    </xconnect-groups>
   </database>
Problem-2: continue the problem-1, when use YDK API to create a VLL circuit configuration, following error result was presenting, you can please refer to attached log file “problme2-vll description error message.txt & problem2-xxx.py”. However, when the “p2p-description” was removed, the configuration could be created successfully without error. May I know the reason?
  <?xml version="1.0"?>
<rpc-reply message-id="urn:uuid:eb2cb296-4d50-11e6-b485-08002722cb22" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<rpc-error>
  <error-type>protocol</error-type>
  <error-tag>bad-element</error-tag>
  <error-severity>error</error-severity>
  <error-path xmlns:ns1="http://cisco.com/ns/yang/Cisco-IOS-XR-l2vpn-cfg">ns1:l2vpn/ns1:database/ns1:xconnect-groups/ns1:xconnect-group[name = 'hinet-eco']/ns1:p2p-xconnects/ns1:p2p-xconnect[name = '10015']/ns1:p2p-description</error-path>
  <error-info>
   <bad-element>p2p-description</bad-element>
  </error-info>
</rpc-error>
</rpc-reply>
Problem-3 : Can not delete VLL circuit configuration by using netconf-yang
*** follows are example configuration of VLL circuit.
interface Bundle-Ether10001.200 l2transport
description "223Y1006--10016--20M/5M"
encapsulation dot1q 200
mtu 1580
l2vpn
xconnect group hinet-eco
  p2p 10016
   neighbor ipv4 172.16.10.2 pw-id 10016
*** use the “problem3-Fail-nc-delete-p2p-ydk.py” to delete the “p2p 10016” circuit, the result was failed and got following error message:
vagrant@ydk-py:models$ ./Fail-nc-delete-p2p-ydk.py -v ssh://cisco:cisco@172.20.10.7
2016-07-21 08:13:28,611 - ydk.providers.NetconfServiceProvider - INFO - NetconfServiceProvider connected to 172.20.10.7:None using ssh
Traceback (most recent call last):
  File "./Fail-nc-delete-p2p-ydk.py", line 91, in <module>
    crud.delete(provider, l2vpn.database.xconnect_groups.xconnect_group.p2p_xconnects.p2p_xconnect)
AttributeError: 'YList' object has no attribute 'p2p_xconnects'
*** use the problem3-nc-delete-xc-group-ydk.py to delete whole xconnect group “hinet-eco”, the result is successful.
einarnn
Andrew,
For problem 1, I'm afraid that the service policy statement is not supported in XR 6.0.1, but will be in XR 6.1.1.
Cheers,
Einar
abhirame
Hi Andrew,
For problem 3, the way to delete a list instance is to create an instance and extend the parent's list with it. There is an example here. Hope this helps.
Abhi
xiaoqinz
Level 4
Level 4
Hi Andrew,
For problem 2, the regex for p2p-description leaf is "[\w\-\.:,_@#%$\+=\|;]+" (link for YANG model), so it is not compatible with value "\"223Y1006--10016--20M/5M\"", maybe it could be changed to some other value? Such as "223Y1006--10016--20M|5M".
Xiaoqin
