/bgp.py Did not receive OK reply and Import DELETE errors
rahkamat
Noob here. Installing YDK first time around.
I have installed ydk but there are a bunch of errors that i am hitting and unable to understand.
If there is documentation which talks about these generic errors,please do let me know
To begin with, this is the pip list for ydk
(openconfig) [root@zion-lnx1 ydk-py-samples]# pip list | grep ydk
ydk                     0.7.1
ydk-models-cisco-ios-xr 6.3.2
ydk-models-ietf         0.1.5
ydk-models-openconfig   0.1.5
I have a NCS6k router on which i have configured the following
netconf agent tty
netconf-yang agent
ssh
ssh server logging
ssh server rate-limit 600
ssh server session-limit 16
ssh server v2
ssh server netconf vrf default
1. ydk-py/core/samples/bgp.py
(openconfig) [root@zion-lnx1 samples]# ./bgp.py -u root -p lab --host=1.80.33.13 --port=830
Establishing connection with device 1.80.33.13:830 using ssh :
Path where models are to be downloaded: /root/.ydk/1.80.33.13_830
Connected to 1.80.33.13 on port 830 using ssh with timeout of -1
connection established...
Executing CRUD delete operation on [openconfig-bgp:bgp]
Data is invalid according to the yang model. Error details: Data model "http://openconfig.net/yang/bgp" not found.
=============Generating payload to send to device=============
<rpc xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<edit-config xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <target>
    <candidate/>
  </target>
  <error-option>rollback-on-error</error-option>
  <config><bgp xmlns="http://openconfig.net/yang/bgp" xmlns:nc="urn:ietf:params:xml:ns:netconf:base:1.0" nc:operation="delete"/>
</config>
</edit-config>
</rpc>
=============Reply payload received from device=============
<?xml version="1.0"?>
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="2">
  <rpc-error>
    <error-type>protocol</error-type>
    <error-tag>unknown-namespace</error-tag>
    <error-severity>error</error-severity>
    <error-info>
      <bad-element>bgp</bad-element>
      <bad-namespace>http://openconfig.net/yang/bgp</bad-namespace>
    </error-info>
  </rpc-error>
</rpc-reply>
Did not receive OK reply from the device -------------> Irrespective of whether or not i have bgp configured, i get this error
BGP config does not exist!
Executing CRUD delete operation on [openconfig-routing-policy:routing-policy]
  <target>
    <candidate/>
  </target>
  <config><routing-policy xmlns="http://openconfig.net/yang/routing-policy" xmlns:nc="urn:ietf:params:xml:ns:netconf:base:1.0" nc:operation="delete"/>
</config>
</edit-config>
</rpc>
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="3">
  <rpc-error>
    <error-type>application</error-type>
    <error-tag>data-missing</error-tag>
    <error-path xmlns:ns1="http://cisco.com/ns/yang/Cisco-IOS-XR-policy-repository-cfg">ns1:routing-policy</error-path>
  </rpc-error>
</rpc-reply>
Routing policy does not exist!
Traceback (most recent call last):
  File "./bgp.py", line 198, in <module>
    bgp_run(crud_service, provider)
  File "./bgp.py", line 109, in bgp_run
    ipv4_afsf.afi_safi_name = openconfig_bgp_types.Ipv4Unicast()
AttributeError: 'module' object has no attribute 'Ipv4Unicast'
2. oc-interfaces.py resulting in the error
(openconfig) [root@zion-lnx1 samples]# ./oc-interfaces.py
  File "./oc-interfaces.py", line 28, in <module>
    from ydk.types import Empty, DELETE, Decimal64
ImportError: cannot import name 'DELETE'
3.  ./ietf_system returning "cannot import name"
(openconfig) [root@zion-lnx1 samples]# ./ietf_system.py
CRUD SERVICE
  File "./ietf_system.py", line 156, in <module>
    ietf_run(crud_service, provider)
  File "./ietf_system.py", line 137, in ietf_run
    from ydk.models.ietf import ietf_system
ImportError: cannot import name 'ietf_system'
Disconnected from device
abhirame
For all 3 issues, it looks like some of those samples are out of date and need to be updated to work with the latest API. Can you try some of the samples here?
https://github.com/CiscoDevNet/ydk-py-samples/tree/master/samples/basic
For the "bad-namespace" error for openconfig-bgp, it looks like the device does not support this model.
abhirame
