Can't fetch configuration data from device
aligang1988
Level 4
Level 4
Hi  !
I tried to run test code with purpose to fetch configuration from device
I used netconf service (both "get" and "get_config" operations), but face an issue
In log I could see messages like:
Can't find data tag in reply sent by device
<requested-device configuration>
</requested-device-configuration>
and
Traceback (most recent call last):
  File "3.py", line 30, in <module>
    configuration = netconf.get(provider, configuration)
  File "/usr/local/lib/python2.7/dist-packages/ydk/services/netconf_service.py", line 133, in get
    result = self._ns.get(provider, filters)
  File "/usr/lib/python2.7/contextlib.py", line 35, in __exit__
    self.gen.throw(type, value, traceback)
  File "/usr/local/lib/python2.7/dist-packages/ydk/errors/error_handler.py", line 82, in handle_runtime_error
    _raise(_exc)
  File "/usr/local/lib/python2.7/dist-packages/ydk/errors/error_handler.py", line 56, in _raise
    raise exc
ydk.errors.YServiceProviderError:
Test code in attachement
Could you please help to understand, what am I doing wrong or what could be a reason of an issue ?
Thanks !
abhirame
The last line of your script seems to be missing a parameter (see docs):
configuration = junos_configuration.Configuration()
read_configuration = netconf.get_config(provider, Datastore.running, configuration)
Also can you please includes any logs you are seeing?
Hi, Abhirame !
I ran 2 samples of code. Both considers your recommendation, one of them contains "filter" argument, another not (samples and logs in attachment).
In both cases, log written using standard python logging contains "Can't find data tag in reply sent by device"
and such message is given in shell
  File "filter_undefined.py", line 30, in <module>
    read_configuration = netconf.get_config(provider, Datastore.running)
  File "/usr/local/lib/python2.7/dist-packages/ydk/services/netconf_service.py", line 108, in get_config
    return _read_entities(provider, True, source)
    _raise(_exc)
    raise exc
ydk.errors.YServiceProviderError: // full_device_configuration_in_xml_format
Thanks!
OK, Thanks !
