Cisco-IOS-XE-interfaces/ospf dont load in YANGSUITE
undutchable
Hello, i'm trying to browse and load some .yang models for a Cat 9k. Whether I download the models straight from my switch with NETCONF, or download from the YANG Git repo, several modules won't load, with this error: yang.jpg
models like -oper do load. All the models work with pyang. Am I missing something?
Marcel Zehnder
Hi @undutchable This bahaviour is expected with IOS-XE. Almost all configuration is done using the Cisco-IOS-XE-native model. The sub-modules (such as Cisco-IOS-XE-interfaces) augment/extend the native model. In other words, the sub-modules are included in the native model. In your case, you'll find the interface related configuration under native/interfaces.
undutchable
Great thank you for your reply, very helpful.
