Configuring interface with NetconfService returns "Unsupported capability :candidate"
MahdiR
I'm testing interface configuration using NetconfService, but i get the following error:
Traceback (most recent call last):
  File "test.py", line 32, in <module>
    service.edit_config(provider=provider, target=Datastore.candidate, config=ifc)
  File "/home/sima-dev/.local/lib/python3.6/site-packages/ydk/services/netconf_service.py", line 103, in edit_config
    default_operation, test_option, error_option)
  File "/usr/lib/python3.6/contextlib.py", line 99, in __exit__
    self.gen.throw(type, value, traceback)
  File "/home/sima-dev/.local/lib/python3.6/site-packages/ydk/errors/error_handler.py", line 82, in handle_runtime_error
    _raise(_exc)
  File "/home/sima-dev/.local/lib/python3.6/site-packages/ydk/errors/error_handler.py", line 54, in _raise
    exec("raise exc from None")
  File "<string>", line 1, in <module>
ydk.errors.YServiceProviderError:  Unsupported capability :candidate
And I found this in the output of the logger:
<error-message xml:lang="en">Unsupported capability :candidate</error-message>
Should Datastore.candidate be a supported capability on the device? I thought this was implied as long as the device supported netconf!
Here is the code:  (This is my first time configuring via netconf, so it might also be something that I'm doing wrong in the code)
import logging
import ydk.models.cisco_ios_xe.Cisco_IOS_XE_interfaces_oper as ifc_oper
from ydk.services.netconf_service import NetconfService
from ydk.services import Datastore
from ydk.providers.netconf_provider import NetconfServiceProvider
def enable_logging(level):
    log = logging.getLogger('ydk')
    log.setLevel(level)
    handler = logging.StreamHandler()
    formatter = logging.Formatter(
        "%(asctime)s - %(name)s - %(levelname)s - %(message)s")
    handler.setFormatter(formatter)
    log.addHandler(handler)
if __name__ == "__main__":
    enable_logging(logging.INFO)
    service = NetconfService()
    provider = NetconfServiceProvider(address="ip",
                                      username="username",
                                      password="password")
    model = ifc_oper.Interfaces()
    ifc = ifc_oper.Interfaces.Interface()
    ifc.name = "GigabitEthernet0/0/7"
    ifc.description = "test description"
    model.interface.append(ifc)
    interface = service.get(provider=provider, read_filter=ifc)
    print(interface.description)
Hi Mahdi
The issue here is that you are using status model Cisco_IOS_XE_interfaces_oper to do the interface configuration. That is why you are getting not-writable error. Please use Cisco_IOS_XE_interfaces_cfg model for interface configuration, then you can use status model to get interface status.
Yan Gorelik
YDK Solutions
10 Replies 10
yangorelik
Hi Mahdi
The script looks fine. The issue could be with the router, which apparently does not support candidate datastore. Try simply replace this line:
   service.edit_config(provider=provider, target=Datastore.running, config=ifc)
Yan Gorelik
YDK Solutions
I get this when I run the code with Datastore.running:
  File "/home/sima-dev/simon_dev/pyenivest/customer_unit/test.py", line 33, in <module>
  File "/usr/lib/python3.6/contextlib.py", line 99, in exit
    _raise(_exc)
ydk.errors.YServiceProviderError:  object is not writable
2020-09-11 08:28:32,136 - ydk - INFO - Disconnected from device
What are the best practices for configuration? using running datastore or candidate?
When you connect to the Netconf service using NetconfServiceProvider, it reads device capabilities (logged only on DEBUG level). Here example for Cisco IOS XE. YDK sends request RPC:
2020-09-11 08:56:04,605 - ydk - DEBUG - Trace: Writing message (session
<?xml version="1.0" encoding="UTF-8"?>
<hello xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<capabilities>
<capability>urn:ietf:params:netconf:base:1.0</capability
<capability>urn:ietf:params:netconf:base:1.1</capability>
<capability>urn:ietf:params:netconf:capability:writable-running:1.0</capability>
<capability>urn:ietf:params:netconf:capability:candidate:1.0</capability>
<capability>urn:ietf:params:netconf:capability:startup:1.0</capability>
<capability>urn:ietf:params:netconf:capability:rollback-on-error:1.0</capability>
</capabilities>
</hello>
Receives from device:
2020-09-11 08:56:05,133 - ydk - DEBUG - Trace: Received message (session
<capabilities>
<capability>urn:ietf:params:netconf:base:1.0</capability>
<capability>urn:ietf:params:netconf:capability:xpath:1.0</capability>
<capability>urn:ietf:params:netconf:capability:validate:1.0</capability>
<capability>urn:ietf:params:netconf:capability:validate:1.1</capability>
<capability>urn:ietf:params:netconf:capability:notification:1.0</capability>
<capability>urn:ietf:params:netconf:capability:interleave:1.0</capability>
<capability>urn:ietf:params:netconf:capability:with-defaults:1.0?basic-mode=explicit&amp;also-supported=report-all-tagged</capability>
<capability>urn:ietf:params:netconf:capability:yang-library:1.0?revision=2016-06-21&amp;module-set-id=730825758336af65af9606c071685c05</capability>
<capability>http://tail-f.com/ns/netconf/actions/1.0</capability>
Here you can see that the device supports only running datastore, which means you can write configuration directly to running configuration.
Alternatively, the IOS XR supports candidate configuration, which means that all device configurations must be done in the candidate datastore and then committed to the running config.
Please run your script with DEBUG logging level and check what capabilities your device is supporting. Attach the log to the post for better understanding of what is going on.
Yan Gorelik
YDK Solutions
I've attached the output, using DEBUG logging level.
It looks like my device supports running, however I'm not sure why I still get the error!
Something wrong with connectivity to the device - the YDK connects to device, gets all the capabilities, gets YANG1.1 capabilities and then unexpectedly sends disconnect request.
2020-09-12 07:09:31,568 - ydk - INFO - Connected to FRD-ASR920-Utviklingtest01 on port 830 using ssh with timeout of -1
2020-09-12 07:09:31,575 - ydk - INFO - Disconnected from device
2020-09-12 07:09:31,576 - ydk - DEBUG - Trace: Writing message (session 102):
<rpc xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="2">
<close-session/>
</rpc>
2020-09-12 07:09:31,618 - ydk - DEBUG - Trace: Received message (session 102):
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="2"><ok/></rpc-reply>
There are no error messages. Very strange!
Could you please try to pass top entity to the netconf service call, like this:
    ifcs = ifc_oper.Interfaces()
    ifcs.interface.append(ifc)
service.edit_config(provider=provider, target=Datastore.running, config=ifcs)
interfaces = service.get(provider=provider, read_filter=ifc_oper.Interfaces())
Yan Gorelik
YDK Solutions
I've attached the output, passing top entity to netconf service call.
Again, you are trying to write to 'candidate' datastore, which is not supported on your device. Error:
You need to write directly to the 'running' datastore.
Yan Gorelik
YDK Solutions
Sorry about that! I've attached the new output.
But it still gives me the same error as before, that running config is not writable! Even though the device supports that capability.
Hi Mahdi
Yan Gorelik
YDK Solutions
Aahh of course, I see now!
Should've checked the first lines in the script and not obsessed over the code and the logger output.
Thanks a lot! everything works flawlessly now.
