Error when using frame size increase
yufenwan
Community Member
Hi experts,
I'm using TRex STL API.
There's only one stream added on my trex port.
Here is the json data I get by the get_stream API in trex_stl_port.py before starting the traffic.
{'mode': {'type': 'continuous', 'rate': {'value': 100, 'type': 'pps'}}, 'enabled': True, 'isg': 0, 'vm': {'instructions': [{'init_value': 64, 'step': 1, 'size': 2, 'max_value': 256, 'name': 'pkt_len', 'op': 'inc', 'type': 'flow_var', 'min_value': 64}, {'name': 'pkt_len', 'type': 'trim_pkt_size'}, {'is_big_endian': True, 'type': 'write_flow_var', 'add_value': -14, 'name': 'pkt_len', 'pkt_offset': 16}]}, 'name': 'test_stream', 'action_count': 0, 'flags': 3, 'self_start': True, 'flow_stats': {'enabled': False}, 'packet': {'meta': '', 'binary': '9E4FOimSoDafjQuOCABFAAAoAAEAAEAGIaIhCwsMIgsLDAQBBAEAAff6AAAAAFAABAAAAAAA'}}
The following error raised when I'm tring to start the traffic.
Exception stack (most recent call last):
#2     Client.py:512                    - 'synchronized=synchronized,'
#1     trex_stl_client.py:1236          - 'ret = f(*args, **kwargs)'
#0     trex_stl_client.py:2719          - 'raise STLError(rc)'
Summary error message:
Port 2 : *** *** error: instruction id '0' min packet size 60 is bigger or eq to max packet size 60
I'm really confused about this error.
Could you help look into this issue?
6 Replies 6
hhaim@cisco.com
Packet size should be bigger than trim instruction var size.
Packet with len 60 can’t be trim to be 256
Thanks.
Hanoh
Hi Hanoch,
Should I modify something?
I read the code in trex_stl_hltapi.py and did the same way according to that.
Yufeng.
Please send to our mailer the full script
Hanoh
Sent from my iPhone
Hi Hanoch,
What's the mailer name?
Yufeng.
https://trex-tgn.cisco.com/trex/doc/index.html
See the forum link
Hanoh
Sent from my iPhone
Hi Hanoch,
Thanks for your help.
The above issue has been solved and is caused by payload data.
