HTTPError: 405 Client Error: Method Not Allowed when pushing yang data
behnamyazdani
Community Member
I'm trying to push some data using nornir framework, however when I receive error 404: method not allowed Error.
I'm using IOS-XE version 16.9.3  with csr1000v as my  test environment.
Python version: 3.7.3
There many policy-map configured on the device and what I'm trying to achieve is to change only a single policy-map config without changing other policy-maps.
He're is my code and It's respective host.yaml and groups.yaml file
#!/usr/bin/python3
import requests
from nornir import InitNornir
from nornir.plugins.tasks.apis import http_method
from nornir.plugins.functions.text import print_result
def manage_devices(task, policy, headers):
    BaseURL = f'https://{task.host.hostname}:{task.host.port}/restconf/'
    task.run(
        task=http_method,
        name='Update policy-map and class-map config via HTTP PUT',
        method='put',
        url=BaseURL + policy,
        auth=('XXXX', 'ZZZZZ'),
        headers=headers,
        verify=False,
        json=task.host['body']['Cisco-IOS-XE-native:policy']['Cisco-IOS-XE-policy:policy-map'][0],
def main():
    requests.packages.urllib3.disable_warnings()
    policy_header = 'data/Cisco-IOS-XE-native:native/Cisco-IOS-XE-native:policy/Cisco-IOS-XE-policy:policy-map/'
    PutHeader = {
      'Content-Type': 'application/yang-data+json',
      'Accept': 'application/yang-data+json, application/yang-data.errors+json'
    nornir = InitNornir()
    result = nornir.run(
        task=manage_devices,
        name='Configure devices via RESTCONF',
        policy=policy_header,
        headers=PutHeader,
    print_result(result)
if __name__ == '__main__':
    main()
hosts file:
PE-R2:
  hostname: '172.17.105.6'
  port: '8802'
  groups:
    - 'csr1000v'
  data:
    body:
      Cisco-IOS-XE-native:policy:
        Cisco-IOS-XE-policy:class-map:
        - name: CLASS_TEST
          prematch: match-all
          match:
            access-group:
              name:
              - ACL_COUNT_TEST
        Cisco-IOS-XE-policy:policy-map:
        - name: POLICY_TEST
          class:
          - name: CLASS_TEST
groups file
csr1000v:
 username: 'XXXX'
 password: 'ZZZZ'
 platform: 'ios'
It seems I'm not able to figure out the correct format to push configs to router.
I'm getting this Error message when running script:
requests.exceptions.HTTPError: 405 Client Error: Method Not Allowed for url: https://172.17.105.6:8802/restconf/data/Cisco-IOS-XE-native:native/Cisco-IOS-XE-native:policy/Cisco-IOS-XE-policy:policy-map/
ygorelik
This is known YDK issue. Unfortunately the IOS XE does not allow to have non-secure Restconf connection and YDK does not support secure HTTP connection. We will fix that issue as resources permit.
I'm not sure how is it related to that issue but the point is if I send without specifying nested keys like following snippet, configuration are pushed to router successfully:
But when I try to push an specific part of the data, I receive '405 Client Error: Method Not Allowed for URL:'
