IDE autocomplete: XE_native model
pmorvay
Hi Could you please help, how to have autocomplete XE native model working?
It has 86MB and PyCharm does not work.
Can you please help, how to help set IDE. E.g. Atom?
I was not able to find out, what exactly I need to enable https://flight-manual.atom.io/using-atom/sections/autocomplete/
abhirame
I don't know. I use ipython and autocomplete works there though it can be a little slow at times. Can you check the documentation of your IDE?
