ImportError: dynamic module does not define module export function (PyInit_ydk_)
vipaoqun@hotmail.com
[root@localhost ydk-gen]#
[root@localhost ydk-gen]# cat /etc/centos-release
CentOS Linux release 7.5.1804 (Core)
[root@localhost ydk-gen]# python -V
Python 3.6.2
[root@localhost ydk-gen]# python -m pip list
Package                 Version
alabaster               0.7.12
Babel                   2.6.0
docutils                0.14
gitdb                   0.6.4
GitPython               1.0.1
imagesize               1.1.0
Jinja2                  2.10
MarkupSafe              1.1.0
pbr                     5.1.1
pip                     18.1
pyang                   1.6
pybind11                2.2.4
Pygments                2.2.0
pytz                    2018.7
rstr                    2.2.6
setuptools              28.8.0
six                     1.11.0
smmap                   0.9.0
snowballstemmer         1.2.1
Sphinx                  1.4a1
sphinx-rtd-theme        0.1.9
stevedore               1.30.0
virtualenv              16.1.0
virtualenv-clone        0.4.0
virtualenvwrapper       4.8.2
ydk                     0.7.3
ydk-models-cisco-ios-xr 6.5.1
ydk-models-ietf         0.1.5.post2
Python 3.6.2 (default, Nov 21 2018, 21:44:58)
[GCC 4.8.5 20150623 (Red Hat 4.8.5-28)] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> from ydk import *
>>> from ydk.types import Empty
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
  File "/usr/local/python3.6/lib/python3.6/site-packages/ydk/types/__init__.py", line 17, in <module>
    from .py_types import Entity, EntityCollection, Config, Filter, YList, YLeafList
  File "/usr/local/python3.6/lib/python3.6/site-packages/ydk/types/py_types.py", line 35, in <module>
    from ydk_ import is_set
>>> from ydk.services import CRUDService
  File "/usr/local/python3.6/lib/python3.6/site-packages/ydk/services/__init__.py", line 17, in <module>
    from .codec_service import CodecService
  File "/usr/local/python3.6/lib/python3.6/site-packages/ydk/services/codec_service.py", line 21, in <module>
    from ydk.entity_utils import get_data_node_from_entity as _get_data_node_from_entity
  File "/usr/local/python3.6/lib/python3.6/site-packages/ydk/entity_utils/__init__.py", line 17, in <module>
    from ydk.ext.entity_utils import get_data_node_from_entity
  File "/usr/local/python3.6/lib/python3.6/site-packages/ydk/exthook.py", line 87, in load_module
    raise ImportError('No module named %s' % fullname)
ImportError: No module named ydk.ext.entity_utils
Please suggest what is wrong and how to fix it?
ygorelik
The main issue is showing up in line:
[GCC 4.8.5
The YDK is built using gcc-5 and g++-5. Please check System Requirements.
In order to upgrade your C and C++ compilers, please execute the following commands on your RedHat system:
$ sudo yum install epel-release
$ sudo yum install libssh-devel gcc-c++ python-devel
$ sudo yum install https://devhub.cisco.com/artifactory/rpm-ydk/0.7.3/libydk-0.7.3-1.x86_64.rpm
# Upgrade compiler to gcc 5.*
$ sudo yum install centos-release-scl -y > /dev/null
$ sudo yum install devtoolset-4-gcc* -y > /dev/null
$ sudo ln -sf /opt/rh/devtoolset-4/root/usr/bin/gcc /usr/bin/cc
$ sudo ln -sf /opt/rh/devtoolset-4/root/usr/bin/g++ /usr/bin/c++
ygorelik, thanks for your timely update, it still works well in python2 but not in python3, it shows as belows and please notice that both of them are built using GCC 4.8.5:
[root@localhost ~]#
[root@localhost ~]#
[root@localhost ~]# sudo yum install epel-release
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
 * base: centos.nethub.com.hk
 * epel: mirror2.totbb.net
 * extras: centos.nethub.com.hk
 * updates: centos.nethub.com.hk
rabbitmq_erlang/x86_64/signature        |  836 B  00:00:00
rabbitmq_erlang/x86_64/signature        | 1.0 kB  00:00:00 !!!
rabbitmq_erlang-source/signature        |  836 B  00:00:00
rabbitmq_erlang-source/signature        |  951 B  00:00:00 !!!
Package epel-release-7-11.noarch already installed and latest version
Nothing to do
[root@localhost ~]#
[root@localhost ~]#
[root@localhost ~]#
[root@localhost ~]# sudo yum install libssh-devel gcc-c++ python-devel
Package libssh-devel-0.7.1-3.el7.x86_64 already installed and latest version
Package gcc-c++-4.8.5-28.el7_5.1.x86_64 already installed and latest version
Package python-devel-2.7.5-69.el7_5.x86_64 already installed and latest version
Nothing to do
[root@localhost ~]#
[root@localhost ~]#
[root@localhost ~]# sudo yum install https://devhub.cisco.com/artifactory/rpm-ydk/0.7.3/libydk-0.7.3-1.x86_64.rpm
libydk-0.7.3-1.x86_64.rpm        | 2.1 MB  00:00:01
Examining /var/tmp/yum-root-j0oOQI/libydk-0.7.3-1.x86_64.rpm: libydk-0.7.3-1.x86_64
/var/tmp/yum-root-j0oOQI/libydk-0.7.3-1.x86_64.rpm: does not update installed package.
Error: Nothing to do
[root@localhost ~]#
[root@localhost ~]#
[root@localhost ~]# sudo yum install centos-release-scl -y > /dev/null
[root@localhost ~]#
[root@localhost ~]# sudo yum install devtoolset-4-gcc* -y > /dev/null
[root@localhost ~]#
[root@localhost ~]# sudo ln -sf /opt/rh/devtoolset-4/root/usr/bin/gcc /usr/bin/cc
[root@localhost ~]#
[root@localhost ~]# sudo ln -sf /opt/rh/devtoolset-4/root/usr/bin/g++ /usr/bin/c++
[root@localhost ~]#
[root@localhost ~]#
[root@localhost ~]# python2
Python 2.7.5 (default, Jul 13 2018, 13:06:57)
[GCC 4.8.5 20150623 (Red Hat 4.8.5-28)] on linux2
>>> import ydk
>>> exit()
[root@localhost ~]#
>>> import ydk
>>> exit()
[root@localhost ~]#
Hello vipaoqun
Would you mind to open new issue on GitHub<>. We will then prioritize it and hopefully address the issue.
In the meanwhile please run YDK in Python 2.
ygorelik, thanks for your help, I opened an issue #840 in CiscoDevNet/ydk-gen repo, and I am looking forward to your and your team's reply.
