Installation procedure with ODL
marcelo.blanes
How can I install it and works together with ODL SDN controller?
Marcelo.
alzverev
Hi Marcello,
Yes, check out examples on DevNet Labs: https://developer.cisco.com/site/devnetlabs/
Could not find any example in DevNet - could you please copy the exact path to an example ? Thanks a lot for your help.
Hi Soumik,
Check out this repo: https://github.com/CiscoDevNet/pathman-sr
There are examples on plugging it into ODL instance.
