Issue configuring multispeed interfaces via NETCONF
julienclaerhout
Visitor
Hi all,
I’m running into an issue when trying to configure multispeed interfaces (10/25/50G) via NETCONF on Catalyst 9600 (C9600-LC-40YL4CD / IOS-XE 17.12).
Context:
  • I need to configure interfaces like FiftyGigE2/0/10 or TwentyFiveGigE1/1/1 via NETCONF (e.g., no switchport, mtu, channel-group, etc.).
  • These interfaces do not appear in the XML schema of the device (get-config on /native/interface/... doesn’t return them).
  • When I attempt to create or modify them (using either Cisco-IOS-XE-native or ietf-interfaces), I get errors like:
inconsistent value: Device refused one or more commands
/if:interfaces/interface[name='FiftyGigE2/0/10']/type is not configured
  • In CLI, the exact same configuration works perfectly.
Hypothesis:
Could this be because these ports are multigig/multispeed and require the speed to be fixed in order to instantiate the interface in YANG?
(I tried forcing speed in CLI and disabling auto-negotiation, but it didn’t change NETCONF behavior.)
Or is this a known limitation of Cisco-IOS-XE-native YANG models with multispeed linecards?
Already tried:
  • Creating the interface via ietf-interfaces with <type>ianaift:ethernetCsmacd</type> → same error.
  • Preconfiguring in CLI (speed 25000, no negotiation auto, no shutdown), then using NETCONF → still rejected.
  • Searched for relevant bugs or caveats (found CSCwk61990 on FiftyGigE not visible via NETCONF but not sure it applies).
Question:
How can I configure multispeed interfaces via NETCONF?
Is there a required sequence (e.g., activate ports in CLI first, then use NETCONF)?
Or is a newer IOS-XE version required for full YANG support?
Any alternative approaches (different YANG model)?
Thanks in advance for any insights.
Digging into very grey matter in my mind here, but think this is a limitation in XE, as (and i am happy to be wrong here) the get-config does not pull these back because they are considered "virtual" or "dormant" state until they're explicitly configured with a specific speed. The YANG models can't see or manipulate interfaces that haven't been "instantiated" with a fixed speed configuration.
I think (guess here) and read this was better in later versions of XE. In the mean time, you could use CLI for initial speed configuration, then NETCONF after?
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
I went ahead and tried your suggestion: I fixed the speed on one of the multispeed interfaces via CLI (speed 25000, speed nonegotiate, no shutdown).
Unfortunately:
  • The interface still does not appear in the YANG model when doing a get-config.
  • Attempts to configure it via NETCONF still return same errors
So even after instantiating the interface with a fixed speed, NETCONF does not seem to have visibility or write access to it.
This makes me wonder:
->  Are these multispeed interfaces simply not configurable via NETCONF at all on IOS-XE 17.12 (even after being initialized)?
->  Or is there a workaround (other than falling back to CLI for those ports)?
I’d really prefer to avoid mixing CLI and NETCONF in my playbooks if possible.
Thanks for testing this, i would agree this appears to be a platform limitation and hopefully if you upgradee addressed in later release/version.
First, I did not test it in XE but for OpenConfig in XR I tried the following NSO template:
<config-template xmlns="http://tail-f.com/ns/config/1.0">
  <?set MTU={/mtu}?>
  <devices xmlns="http://tail-f.com/ns/ncs">
    <?foreach {/device}?>
    <device>
      <name>{./name}</name>
      <config>
        <interfaces xmlns="http://openconfig.net/yang/interfaces">
          <?foreach {interfaces}?>
          <interface>
            <name>{type}{name}</name>
            <config>
              <type xmlns:ianaift="urn:ietf:params:xml:ns:yang:iana-if-type">ianaift:ethernetCsmacd</type>
              <mtu>{$MTU}</mtu>
            </config>
            <hold-time>
              <config>
                <up>10</up>
              </config>
            </hold-time>
          </interface>
          <?end?><!--foreach {interfaces}-->
        </interfaces>
      </config>
    </device>
    <?end?><!--foreach {device}-->
  </devices>
</config-template>
So, from my experience and looking at the YANG model, the "type" leaf is mandatory but you need to add the correct namespace as it uses a IANA model definition: <type xmlns:ianaift="urn:ietf:params:xml:ns:yang:iana-if-type">ianaift:ethernetCsmacd</type>
Maybe try this encoding for the type.
