Making leaf node Conditional mandatory in yang
nikhilagarwal.85
Community Member
I am trying to make a leaf node as conditional mandatory as explained below.
list top-list {
   leaf type {
     description "type.";
     mandatory true;
     type network-type; /// this type has 3 values i.e local/remote/gr-remote
   leaf node {
     description "Node details.";
     type leafref {
      path /// -- some reference
     mandatory true;
     when "../type = 'local'";
Now here, the ask is to have node as mandatory when type is local and optional when type is gr-remote and not allowed when type is local.
I am able to make both local & gr-remote as either mandatory or option via using "when" but not able to make leaf "node" as mandatory when type  is "local" and optional when type is "gr-remote".
Any leads on this would be helpful.
Thank in advance.
Nikhil
Alexander Stevenson
Hi @nikhilagarwal.85,
I see that no YANG experts have commented so I'll make a suggestion. You might want to try the 'refine' statement and/or the 'default' sub-statement as described in these two StackOverflow discussions:
Hope this helps!
