NeXt 'force' dataProcessor resets saved view
Suterusu1337
I found if I save a topology from NeXt using:
save = function() {
        localStorage.setItem('topology', JSON.stringify(topology.graph().getData()));
Then I try and load the saved data:
    load = function() {
        topology.setData(JSON.parse(localStorage.getItem('topology')));
if I am using the "force" dataProcessor:
dataProcessor: 'force'
Whenever I save -> load the topology, even with no changes made manually, the topology will always shift or reset.
Is there a way to load the topology without the data processor restructuring the data?
Suterusu1337
I added this and I think it is working:
    load = function() {
        topology.dataProcessor("")
        topology.data(JSON.parse(localStorage.getItem('topology')));
