Problem during do-release-upgrade
Laurent Protti
Level 2
Level 2
Hello, I'm trying to upgrade our VIRL server, however, when I launch this command, I've got this result and I'm at a loss to find a solution to this.
any suggestions would be welcome 🙂
Unknown Multi-Arch type 'no' for package 'compiz-core'
Unknown Multi-Arch type 'no' for package 'compiz-gnome'
Unknown Multi-Arch type 'no' for package 'libxapian-dev'
Ignoring Provides line with DepCompareOp for package python-cffi-backend-api-max
Ignoring Provides line with DepCompareOp for package python-cffi-backend-api-min
Ignoring Provides line with DepCompareOp for package python3-cffi-backend-api-max
Ignoring Provides line with DepCompareOp for package python3-cffi-backend-api-min
Unknown Multi-Arch type 'no' for package 'kwin'
Unknown Multi-Arch type 'no' for package 'kwin-dev'
Unknown Multi-Arch type 'no' for package 'kwin-wayland'
Unknown Multi-Arch type 'no' for package 'kwin-x11'
Unknown Multi-Arch type 'no' for package 'libkf5sysguard-dev'
Ignoring Provides line with DepCompareOp for package php-psr-http-message-implementation
Ignoring Provides line with DepCompareOp for package php-psr-log-implementation
Ignoring Provides line with DepCompareOp for package php-seclib
Ignoring Provides line with DepCompareOp for package php-sabre-http
Ignoring Provides line with DepCompareOp for package php-math-biginteger
Ignoring Provides line with DepCompareOp for package pypy-cffi
Ignoring Provides line with DepCompareOp for package pypy-cffi-backend-api-max
Ignoring Provides line with DepCompareOp for package pypy-cffi-backend-api-min
Ignoring Provides line with DepCompareOp for package xserver-xorg
You may want to run apt-get update to correct these problems
Checking package manager
Reading package lists... Done
Building dependency tree
Reading state information... Done
  Hold prevents MarkGarbage of qemu-system-common [ amd64 ] < 1:2.2+dfsg-5expubuntu9.7~cloud5 -> 1:2.5+dfsg-5ubuntu10.10 > ( misc )
  Hold prevents MarkGarbage of python-dateutil [ amd64 ] < 1.5+dfsg-1ubuntu1 -> 2.4.2-1 > ( python )
  Hold prevents MarkGarbage of qemu-system-x86 [ amd64 ] < 1:2.2+dfsg-5expubuntu9.7~cloud5 -> 1:2.5+dfsg-5ubuntu10.10 > ( misc )
Building data structures... Done
Calculating the changes
Could not calculate the upgrade
An unresolvable problem occurred while calculating the upgrade.
This can be caused by:
* Upgrading to a pre-release version of Ubuntu
* Running the current pre-release version of Ubuntu
* Unofficial software packages not provided by Ubuntu
If none of this applies, then please report this bug using the
command 'ubuntu-bug ubuntu-release-upgrader-core' in a terminal.
Restoring original system state
Geevarghese Cheria
Hi Laurent,
  Apologies for the delay in responding to you. Please check this related document for more info- VIRL 1.2.83 (October 2016 Release) - 31438 - The Cisco Learning Network
Also for further questions request to post under  new space -  ttps://learningnetwork.cisco.com/groups/virl
Thanks and Regards,
Geevarghese
