PYATS failed to connect (even though it does)
MK9796
I have a project coming up to do some DHCP helper updates enterprise wide. I was hoping to use pyATS to confirm the changes. I started with this simple yaml file in my lab. I get a failed to connect even though the log shows it connecting. I think I'm missing something simple. I can't really come up with a simpler test. The yaml file is attached.
Test device is a Catalyst 3560. I can successfully login with the credentials and have priv 15 access.
Command:
genie learn all -v -v -v --testbed-file example.yaml
loading yaml file example.yaml
Learning '['acl', 'arp', 'bgp', 'dot1x', 'eigrp', 'fdb', 'hsrp', 'igmp', 'interface', 'lag', 'lisp', 'lldp', 'mcast', 'mld', 'msdp', 'nd', 'ntp', 'ospf', 'pim', 'platform', 'prefix_list', 'rip', 'route_policy', 'routing', 'static_routing', 'stp', 'vlan', 'vrf', 'vxlan', 'config']' on devices '['sw1']'
failed to connect to sw1
Log:
[2019-07-01 10:50:25,016] +++ sw1 logfile ./connection_sw1.txt +++
[2019-07-01 10:50:25,016] +++ Unicon plugin ios +++
Trying 192.168.1.157...
[2019-07-01 10:50:25,023] +++ connection to spawn: telnet 192.168.1.157, id: 140148915360768 +++
[2019-07-01 10:50:25,023] connection to sw1
Connected to 192.168.1.157.
Escape character is '^]'.
User Access Verification
Username: cisco
Password:
SW1#
Seb Rupik
Hi there,
I've not had a chance to test pyATS yet, but I'm going to take a wild guess...
The device name (or maybe the alias) probably has to match the hostname shown on the CLI prompt. This is probably a fail safe to verify you have connected to the device you think it is. I'd suggest changing your yaml file to:
testbed:
  tacacs:
      username: "cisco"
  passwords:
      tacacs: "cisco"
      enable: "cisco"
      line: "cisco"
devices:
  SW1:
    alias: SW1
....<etc>....
cheers,
Seb.
I had the same problem but thanks to @Seb Rupik hint the connection to devices is now working without a problem
Thank you again @Seb Rupik
