searching for nodes
m.rainer
Level 2
Level 2
I would like to search for nodes (by name or other parameters) in my topology.
After finding I would like to "select" them.
So I have to iterate over all nodes.
This already works fine for all nodes shown in the current view. (found many different ways to do so p.e.:
topology.eachNode()
or
topology.graph().eachVertex()
and so on.
BUT:
As soon as a node is "hidden" behind a nodeSet this does not work.
So I am looking for a method to find all Nodes in my topology also those being hidden behind nodeSets.
topology.getData() does not help, as I can not select them there...
AND:
If I was able to find currently hidden nodes, and I select them, is there a way to select all nodeSet(s) that are parents of this node?
Again: Node is nested under NodeSets. If searched for that node I would like to "select" all the tree to the searched Node.
Ist this possible?
Thx a lot
Markus
aaikepae
Hi Markus,
there are couple steps you can fellow:
1. find vertex :  vertex = topo.graph().getVertex(ID)
2. check if vertex generated : vertex = generated()
3. if yes, just use topo.getNode(ID)
4. if not use this property find generated parent nodeset : var vs = vertex.generatedRootVertexSet(),
5 use topo.getNode(vs.id()) find parent nodeSet
Abu
