Some questions regarding ydk.filters
Can you give me some guidance on ydk.filters ?
I would like to figure out the principle that how to use ydk.filters ?
Below are some examples from Python YDK API document.
I have some findings from below examples but I am not sure if I am correct and I am sure it is only part of it not full.  Can you please give me full overview how to use ydk.filter.?
Thanks a lot
1 if attribute is a leaf we could use
ins.running = YFilter.read   (running is a leaf)   read one specific leaf
cdp.timer = YFilter.delete   (timeer is a leaf)     delete one specific leaf
2 if attribute is a list or container
bgp.global_.config.yfilter = YFilter.replace   (config is container)
route.yfilter = YFilter.read (route is list)
ins.yfilter = YFilter.delete    (ins is list)
from ydk.filters import YFilter
1st
# First create the top-level Isis() object
isis = Cisco_IOS_XR_clns_isis_cfg.Isis()
# Create the list instance
ins = Cisco_IOS_XR_clns_isis_cfg.Isis.Instances.Instance()
ins.instance_name = 'default'
# Set the yfilter attribute of the leaf called 'running' to YFilter.read
2nd
ins.instance_name = 'xyz'
# Set the yfilter attribute of the leaf called 'running' to YFilter.delete
# Append the instance to the parent
3rd
# First create the top-level Cdp() object
cdp = Cisco_IOS_XR_cdp_cfg.Cdp()
# Set a dummy value to the leaf
cdp.timer = 5
# Assign YFilter.delete to the 'timer' leaf
4th
# Assign YFilter.delete to the 'running' leaf
ins.running = YFilter.delete
isis.instances.instance.append(ins)
3rd
Jacky Zhang
Global Telecom
yangorelik
The ydk.filters used to attach Netconf operations to specific YANG model nodes (leaf, list, container). They are used to read, update, or delete those nodes. Each example in the documentation shows how to apply the filters for different types of nodes. Please run the scripts for better understanding.
Yan Gorelik
YDK Solutions
