Suppress Genie output when using in a script
Mike Assel
Level 4
Level 4
I'm playing around with using Genie in a python script. Whenever I do anything with Genie, like device.connect(), it prints the output to the console. How do I suppress that?  Thanks, Mike
After further research, there are two other methods:
1) When you initially connect to a device, you can pass the argument dev.connect(log_stdout=False) to disable logging; this disable will be in-effect for the entire session until you re-enable it.
2) The device instance, after connection, provide a dev.log_user() method, which can be enabled/disabled passing True/False.
9 Replies 9
Jeremy Schulman
Given a device instance, you can change the log settings via the connectionmgr instance.
For example:
import logging
# dev is a Device instance from a testbed
dev.connectionmgr.log.setLevel(logging.ERROR)
# now execute a command and you will not see the output on the console
resp = dev.execute('show version')
# you can print the response
print(resp)
Thanks Jeremy! That did the trick. However when I use dev.connect(log_stdout=False) then the output is not logged to a file. A few follow up questions:
  1. How did you find dev.connect(log_stdout=False) ???? I did a lot of googling and NOTHING comes up (other than your blog post :)
  2. Assuming I can disable logging to the console but enable logging to a file, how would I specify the path?
Hi @Mike Assel,
re: connect(log_stdout=False) I learned via a response on Twitter from one of the DevNet genie developers.  After I learned this, I did a scan of the sourcecode and I could not find any reference to this Device() argument either.  Seem like an opportunity for the DevNet team to add more documentation.
re: logging - even though the console logging is disabled, there is still a logfile.  You can find it using the Device.logfile attribute, for example:
In [11]: dev.logfile
Out[11]: '/tmp/atlrs21-cli-20191021T024126194.log'
I have not experimented with changing the logfile value.
Hope this helps!
My bad. I had checked and thought I did not see a log file, but I checked again and indeed it was there. Thanks for the help.
@Jeremy Schulman
I know this is a blast from the past but would you be willing to take a walk down memory lane and walk me through how you found this?  I've spent hours trying it myself.  I think my hold up is I can't even find the connect method that the object of class genie.libs.conf.device.nxos.device.Device can run to inspect the code.  I looked into all the inherited classes but didn't find a connect method.  Using the inspect module it looks like it my be written in C and maybe thats why I can't see the code.  How did you find out the exact syntax to use?
I'm using this code in ipython to test
from genie import testbed
tb = testbed.load(".\testbed.yaml")
core1 = tb.devices.Core1
core1.connect()
nevermind, I completely missed the post where you got that straight from a dev
stumbled across the documentation for the connect method.  It uses another cisco framework call Unicon.  On their docs it lists out the options you can use for pyats
https://developer.cisco.com/docs/unicon/
Here's a direct link to the Unicon device connection arguments.
https://pubhub.devnetcloud.com/media/unicon/docs/user_guide/connection.html#python-apis
