Trex hugepage memory issue
bbarot
Community Member
bbarot@trex06.iad0:~/v3.02$ sudo ./_t-rex-64 -i -c 7 --astf --cfg /etc/trex_cfg_593vlan.yaml --mbuf-factor 0.2 -v 7
Starting  TRex v3.02 please wait  ...
Using configuration file /etc/trex_cfg_593vlan.yaml
port limit     :  not configured
port_bandwidth_gb    :  10
port_speed           :  0
port_mtu             :  0
if_mask        : None
prefix              : trex6
is low-end : 0
stack type :
limit_memory        : 2048
thread_per_dual_if      : 1
if        :  --vdev=net_bonding0,mode=2,slave=00:07.0,slave=00:08.0,mac=52:54:00:ee:ee:04, --vdev=net_bonding1,mode=2,slave=00:09.0,slave=00:0a.0,mac=52:54:00:ee:ee:03, --vdev=net_bonding0,mode=2,slave=00:0b.0,slave=00:0c.0,mac=52:54:00:ef:ee:04, --vdev=net_bonding1,mode=2,slave=00:0d.0,slave=00:0e.0,mac=52:54:00:ef:ee:03,
enable_zmq_pub :  1
zmq_pub_port   :  4500
m_zmq_rpc_port    :  4501
src     : 00:00:00:00:00:00
dest    : 00:00:00:00:00:00
memory per 2x10G ports
MBUF_64                                   : 81894
MBUF_128                                  : 40950
MBUF_256                                  : 5000
MBUF_512                                  : 64380
MBUF_1024                                 : 64380
MBUF_2048                                 : 64000
MBUF_4096                                 : 100
MBUF_9K                                   : 100
TRAFFIC_MBUF_64                           : 65520
TRAFFIC_MBUF_128                          : 32760
TRAFFIC_MBUF_256                          : 8190
TRAFFIC_MBUF_512                          : 8190
TRAFFIC_MBUF_1024                         : 8190
TRAFFIC_MBUF_2048                         : 32760
TRAFFIC_MBUF_4096                         : 128
TRAFFIC_MBUF_9K                           : 512
MBUF_DP_FLOWS                             : 524288
MBUF_GLOBAL_FLOWS                         : 5120
master   thread  : 0
rx  thread  : 15
dual_if : 0
    socket  : 0
   [   1   2   3   4   5   6   7
dual_if : 1
    socket  : 1
   [   8   9   10   11   12   13   14
CTimerWheelYamlInfo does not exist
flags           : 18070f00
write_file      : 0
verbose         : 7
realtime        : 1
flip            : 0
cores           : 7
single core     : 0
flow-flip       : 0
no clean close  : 0
zmq_publish     : 1
vlan mode       : 1
client_cfg      : 0
mbuf_cache_disable  : 0
cfg file
mac file
out file
client cfg file :
duration        : 0
factor          : 1
mbuf_factor     : 0
latency         : 0 pkt/sec
zmq_port        : 4500
telnet_port     : 4501
expected_ports  : 4
tw_bucket_usec  : 20.000000 usec
tw_buckets      : 1024 usec
tw_levels       : 3 usec
port : 0 dst:00:00:00:00:00:00  src:00:00:00:00:00:00 vlan:584
port : 1 dst:00:00:00:00:00:00  src:00:00:00:00:00:00 vlan:593
port : 2 dst:00:00:00:00:00:00  src:00:00:00:00:00:00 vlan:610
port : 3 dst:00:00:00:00:00:00  src:00:00:00:00:00:00 vlan:605
port : 4 dst:00:00:00:01:00:00  src:00:00:00:00:00:00 vlan:0
port : 5 dst:00:00:00:01:00:00  src:00:00:00:00:00:00 vlan:0
port : 6 dst:00:00:00:01:00:00  src:00:00:00:00:00:00 vlan:0
port : 7 dst:00:00:00:01:00:00  src:00:00:00:00:00:00 vlan:0
port : 8 dst:00:00:00:01:00:00  src:00:00:00:00:00:00 vlan:0
port : 9 dst:00:00:00:01:00:00  src:00:00:00:00:00:00 vlan:0
port : 10 dst:00:00:00:01:00:00  src:00:00:00:00:00:00 vlan:0
port : 11 dst:00:00:00:01:00:00  src:00:00:00:00:00:00 vlan:0
port : 12 dst:00:00:00:01:00:00  src:00:00:00:00:00:00 vlan:0
port : 13 dst:00:00:00:01:00:00  src:00:00:00:00:00:00 vlan:0
port : 14 dst:00:00:00:01:00:00  src:00:00:00:00:00:00 vlan:0
port : 15 dst:00:00:00:01:00:00  src:00:00:00:00:00:00 vlan:0
port : 16 dst:00:00:00:01:00:00  src:00:00:00:00:00:00 vlan:0
port : 17 dst:00:00:00:01:00:00  src:00:00:00:00:00:00 vlan:0
port : 18 dst:00:00:00:01:00:00  src:00:00:00:00:00:00 vlan:0
port : 19 dst:00:00:00:01:00:00  src:00:00:00:00:00:00 vlan:0
port : 20 dst:00:00:00:01:00:00  src:00:00:00:00:00:00 vlan:0
port : 21 dst:00:00:00:01:00:00  src:00:00:00:00:00:00 vlan:0
port : 22 dst:00:00:00:01:00:00  src:00:00:00:00:00:00 vlan:0
port : 23 dst:00:00:00:01:00:00  src:00:00:00:00:00:00 vlan:0
port : 24 dst:00:00:00:01:00:00  src:00:00:00:00:00:00 vlan:0
port : 25 dst:00:00:00:01:00:00  src:00:00:00:00:00:00 vlan:0
port : 26 dst:00:00:00:01:00:00  src:00:00:00:00:00:00 vlan:0
port : 27 dst:00:00:00:01:00:00  src:00:00:00:00:00:00 vlan:0
port : 28 dst:00:00:00:01:00:00  src:00:00:00:00:00:00 vlan:0
port : 29 dst:00:00:00:01:00:00  src:00:00:00:00:00:00 vlan:0
port : 30 dst:00 port : 31 dst:0 MBUF_128        MBUF_4096       Total memory    core_list : 0,10,0,1,1,0,0,0,0, 4      7
5 8      2
9 13      12
DPDK args
xx  -l  0,15,1,2,3,EAL: Detected CPU lcores: 16
EAL: Detected NUMA nodes: 1
EAL: Detected static linkage of DPDK
EAL: Multi-process socket /var/run/dpdk/trex6/mp_socket
EAL: Selected IOVA mode 'PA'
EAL: VFIO support initialized
EAL: Probe PCI driver: net_i40e_vf (8086:154c) device: 0000:00:07.0 (socket 0)
EAL: Probe PCI driver: net_i40e_vf (8086:154c) device: 0000:00:08.0 (socket 0)
EAL: Probe PCI driver: net_i40e_vf (8086:154c) device: 0000:00:09.0 (socket 0)
EAL: Probe PCI driver: net_i40e_vf (8086:154c) device: 0000:00:0a.0 (socket 0)
EAL: Probe PCI driver: net_i40e_vf (8086:154c) device: 0000:00:0b.0 (socket 0)
EAL: Probe PCI driver: net_i40e_vf (8086:154c) device: 0000:00:0c.0 (socket 0)
EAL: Probe PCI driver: net_i40e_vf (8086:154c) device: 0000:00:0d.0 (socket 0)
EAL: Probe PCI driver: net_i40e_vf (8086:154c) device: 0000:00:0e.0 (socket 0)
TELEMETRY: No legacy callbacks, legacy socket not created
size of interfaces_vdevs 4
===>>>found net_bonding0 8
===>>>found net_bonding1 9
__eth_bond_slave_add_lock_free(476) - Slave device is already a slave of a bonded device
bond_ethdev_configure(3762) - Failed to add port 0 as slave to bonded device net_bonding0
bond_ethdev_configure(3762) - Failed to add port 1 as slave to bonded device net_bonding0
bond_ethdev_configure(3762) - Failed to add port 2 as slave to bonded device net_bonding1
bond_ethdev_configure(3762) - Failed to add port 3 as slave to bonded device net_bonding1
set driver name net_bonding
driver capability  : TCP_UDP_OFFLOAD  TSO  SLRO
set dpdk queues mode to MULTI_QUE
DPDK devices 10 : 10
0 : vdev 00:07.0
1 : vdev 00:08.0
2 : vdev 00:09.0
3 : vdev 00:0a.0
4 : vdev 00:0b.0
5 : vdev 00:0c.0
6 : vdev 00:0d.0
7 : vdev 00:0e.0
8 : vdev net_bonding0
9 : vdev net_bonding1
Number of ports found: 4
if_index : 0
driver name : net_bonding
min_rx_bufsize : 0
max_rx_pktlen  : 9728
max_rx_queues  : 16
max_tx_queues  : 16
max_mac_addrs  : 16
rx_offload_capa : 0x226f
tx_offload_capa : 0x9fbf
rss reta_size   : 64
flow_type_rss   : 0x7ef8
tx_desc_max     : 4096
tx_desc_min     : 0
rx_desc_max     : 4096
rx_desc_min     : 0
set slave driver = net_i40e_vf
zmq publisher at: tcp://*:4500
rx_data_q_num : 0
rx_drop_q_num : 0
rx_dp_q_num   : 7
rx_que_total : 7
rx_desc_num_data_q   : 512
rx_desc_num_drop_q   : 4096
rx_desc_num_dp_q     : 512
total_desc           : 3584
tx_desc_num     : 1024
ERROR there is not enough huge-pages memory in your system
EAL: Error - exiting with code: 1
  Cause: Cannot init mbuf pool small-pkt-const
bbarot@trex06.iad0:~/v3.02$ cat /etc/trex_cfg_593vlan.yaml
### Config file generated by dpdk_setup_ports.py ###
- port_limit: 12
  version: 2
  interfaces: ['--vdev=net_bonding0,mode=2,slave=00:07.0,slave=00:08.0,mac=52:54:00:ee:ee:04', '--vdev=net_bonding1,mode=2,slave=00:09.0,slave=00:0a.0,mac=52:54:00:ee:ee:03' ,'--vdev=net_bonding0,mode=2,slave=00:0b.0,slave=00:0c.0,mac=52:54:00:ef:ee:04', '--vdev=net_bonding1,mode=2,slave=00:0d.0,slave=00:0e.0,mac=52:54:00:ef:ee:03']
  port_info:
      - ip: 10.111.127.158
        default_gw: 10.111.127.181
        vlan: 584
      - ip: 10.136.192.6
        default_gw: 10.136.192.1
        vlan: 593
      - ip: 10.111.72.49
        default_gw: 10.111.72.39
        vlan: 610
      - ip: 10.136.86.250
        default_gw: 10.136.86.1
        vlan: 605
  platform:
      master_thread_id: 0
      latency_thread_id: 15
      dual_if:
        - socket: 0
          threads: [1,2,3,4,5,6,7]
        - socket: 1
          threads: [8,9,10,11,12,13,14]
  memory:
        mbuf_64: 81894
        mbuf_128: 40950
        mbuf_256: 5000
        mbuf_512: 64380
        mbuf_1024: 64380
        mbuf_2048: 64000
        mbuf_4096: 100
        mbuf_9k: 100
From what i have read TRex requires a significant amount of huge-pages memory to run, especially when using the--mbuf-factor option, which controls the amount of memory allocated for packet buffers. You could increase the huge-pages allocation and adjust the values according to your system's requirements or reduce the mbuf-factor value to a lower number, such as 0.1 or 0.05, to reduce the amount of memory required for packet buffers.
Not sure else but if this does not work create an issue on the repo here --> https://github.com/cisco-system-traffic-generator
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
bbarot
Community Member
Thanks @bigevilbeard for the quick response. I have allocated 8G memory. And I had checked the free -h and it shows good amount of free memory available
Happy to throw some thoughts in here! The issue is not with the amount of free memory available, but rather with the allocation of huge pages. Huge pages are used by DPDK to improve performance, and TRex requires a certain amount of huge pages to be allocated. I _think_ you can check this by
cat /proc/meminfo | grep HugePages
Maybe try (update for your needs here btw)
echo 1024 > /sys/kernel/mm/hugepagesize
echo 10000 > /sys/kernel/mm/hugepages/1024kB/nr_hugepages
  Hope this helps.
