TRex tool test the Maximum TCP Connection Establishment Rate
Helsing
Hi guys,
I wonder how to use the TRex tool to test DUT's Maximum TCP Connection Establishment Rate and Maximum Concurrent TCP Connection Capacity?My DUT is a business router, I want to test the above indicators on LAN2WAN traffic model.
Any help will be appreciated.
603864973
hi, you can use the file which the path is astf/http_manual_commands_connect_rst.py
Thx, now I know this file. But how should I config the ".../etc/trex_cfg.yaml" ?
My topo like below:
192.168.0.100(TRex NIC) ------ (LAN ; 192.168.0.1) Router_DUT (WAN ; 192.168.202.22) ------ (TRex NIC)192.168.202.99
My ".../etc/trex_cfg.yaml" as below:
- ip: 192.168.0.100     default_gw: 192.168.0.1
- ip: 192.168.202.99   defaul_gw: 192.168.202.22
