ydk-cpp Installation
ajay.priyadarshi
Community Member
i am using Red Hat Enterprise Linux Server release 6.5 (Santiago) for installation of Ydk-cpp.
I successfully installed the ydk-core, ietf & openconfig, using CXX="g++-49 -std=c++11" CC="gcc" while make install from source.
cisco-ios-xr : This modules takes ages to get installed.
cisco-ios-xe : Still i am unable to install it.
Kindly suggest proper compilation flags which can help me to install all modules.
Sorry about that. The code has been updated to fix this. Please sync to the latest code:
GitHub - CiscoDevNet/ydk-cpp: C++ SDK generated from YANG data models.
The precompiled images for CentOS are available here: https://devhub.cisco.com/artifactory/webapp/#/artifacts/browse/tree/General/rpm-ydk/0.6.3
abhirame
I have seen that the clang compiler is better suited to handle the large number/size of files in ydk-cpp. Let me know if this works for you.
Also, we have pre-compiled binaries (built on Centos7) available at: https://devhub.cisco.com/artifactory/rpm-ydk/0.6.3/ (the XE package will be available soon)
Except cisco-ios-xe  module all modules have been installed.
Getting error while compiling cisco-ios-xe  module.
Error Console log:
from /home/ajay/ydk-cpp-master/cisco-ios-xe/ydk/models/cisco_ios_xe/fragmented/Cisco_IOS_XE_native_95.cpp:2:
/home/ajay/ydk-cpp-master/cisco-ios-xe/ydk/models/cisco_ios_xe/fragmented/Cisco_IOS_XE_native_95.cpp: In constructor âcisco_ios_xe::Cisco_IOS_XE_native::Native::Monitor::EventTrace::Atom::Atom()â:
/home/ajay/ydk-cpp-master/cisco-ios-xe/ydk/models/cisco_ios_xe/fragmented/Cisco_IOS_XE_native_95.cpp:14904:3: error: class âcisco_ios_xe::Cisco_IOS_XE_native::Native::Monitor::EventTrace::Atomâ does not have any field named âgnu_dev_majorâ
  ,major(std::make_shared<Native::Monitor::EventTrace::Atom::Major>())
