YDK Example for Interface Encapsulation
brfoster
Team,
Can someone post example YDK code for configuring interface encapsulation?  Like this XML...
    <config>
      <interface-configurations xmlns="http://cisco.com/ns/yang/Cisco-IOS-XR-ifmgr-cfg">
        <interface-configuration>
          <active>act</active>
          <interface-name>HundredGigE0/0/1/0.11</interface-name>
          <interface-mode-non-physical>l2-transport</interface-mode-non-physical>
          <ethernet-service xmlns="http://cisco.com/ns/yang/Cisco-IOS-XR-l2-eth-infra-cfg">
            <encapsulation>
              <outer-tag-type>match-dot1q</outer-tag-type>
              <outer-range1-low>1011</outer-range1-low>
            </encapsulation>
          </ethernet-service>
yangorelik
I could not find any published example for the path
Cisco-IOS-XR-ifmgr-cfg/interface-configurations/interface-configuration/ethernet-service
The closest examples with the same YANG model can be found here.
Are you experiencing any specific issue related to that YANG model and/or path? What YDK release are you using for your application? What is programming language?
Yan
Yan Gorelik
YDK Solutions
