cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Apresentações
Útil
Respostas
Gateway 3925 - Certificate expiration
Oi pessoal,
Temos em nosso ambiente muitos voice gateways . Recebi a informação sobre a área de segurança que um gateway está com certificado expirado. Não tenho experiência nestas questões. Como posso verificar esta informação e corrigir?
sh version
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.3(3)M3, RELEASE SOFTWARE (fc1)
XYZ#sh inv
NAME: "CISCO3945-CHASSIS", DESCR: "CISCO3945-CHASSIS"
Obrigado,
Wilson
Hi Guys,
We have in our environment many voice gateways. I received the information about the security area that one gateway is with expirated certificate. I don´t have experience about this issues. As I can verify this information and to fix?
sh version
XYZ#sh inv
Wilson
3 RESPOSTAS 3
Leonardo Santana
Olá,
Você sabe qual a finalidade deste certificado que esta expirado?
É um self signed certificate?
Abaixo algumas funcionalidades que requerem um certificado digital:
General Features
  • HTTP Server over TLS (HTTPS) - HTTPS produces an error in the browser which indicates that the certificate is expired.
  • SSH Server - Users who use X.509 certificates to authenticate the SSH session can fail to authenticate. (The use of X.509 certificates is rare. Username/password authentication and public/private key authentication are not affected.)
  • RESTCONF - RESTCONF connections can fail.
Collaboration Features
  • Session Initiation Protocol (SIP) over TLS
  • Cisco Unified Communications Manager Express (CME) with encrypted signaling enabled
  • Cisco Unified Survivable Remote Site Telephony (SRST) with encrypted signaling enabled
  • Cisco IOS dspfarm resources (Conference, Media Termination Point, or Transcoding) with encrypted signaling enabled
  • Skinny Client Control Protocol (SCCP) Telephony Control Application (STCAPP) ports configured with encrypted signaling
  • Media Gateway Control Protocol (MGCP) and H.323 call signaling over IP security (IPSec) without a pre-shared key
  • Cisco Unified Communications Gateway Services API in Secure Mode (that use HTTPS)
Verifique este link para maiores informações:
https://www.cisco.com/c/en/us/support/docs/security-vpn/public-key-infrastructure-pki/215118-ios-self-signed-certificate-expiration-o.html
Neste documento mostra os comandos para identificar aonde este certificado está sendo usado.
Comandos uteis:
show running-config | begin crypto
sh run | se voice service
sh run | se sip-ua
sh run | se dspfarm profile
Leonardo Santana
*** Rate All Helpful Responses***
Boa Tarde Leonardo,
Obrigado pelo seu contato.
Por ora não sei a finalidade do certificado expirado. Tenho pouco tempo de empresa e ainda estou conhecendo a rede como um todo. Vou ler o documento que me enviou e tentarei retornar o mais breve possivel.
Obrigado,
Att,
Wilson
Wilson,
Geralmente o certificado em gateways de voz seria para criptografar o trafego de sinalização (SIP, H323, SCCP, MGCP) e mídia (RTP).
Leonardo Santana
