cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Apresentações
Útil
Respostas
SIP outbound call Disconnect Cause=47
Hello all,
We started having issues with outbound calls with a SIP provider. This below is the call flow:
CUCM -> SIP Trunk -> Voice gateway -> SIP Trunk -> Provider
On the voice gateway, I'm getting a disconnect cause=47. Viewing the logs, it seems that CUCM and VG are able to negotiate the codec g711ulaw, but after this, I can't see the invite to the provider offering the codec.
Could anyone help in this case, please?
CUCM 192.168.1.10
VG 192.168.1.9
4 RESPOSTAS 4
Translator
Community Manager
Community Manager
Verifique se a conexão com o provedor de serviços não está inativa?
Translator
Community Manager
Community Manager
Sua configuração é uma mensagem total.
Você não tem nenhum peer de discagem configurado com SIP entre o gateway e o CUCM.
Seu dial-peer está usando H323. Portanto, a chamada provavelmente falhará.
There's a dial peer between CUCM and gateway, that shows as incoming dial-peer on the logs: Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=105
Those SIP messages are also between CUCM and GW. I can see that outgoing dial-peer gets selected, but never see any SIP messages to the provider.
Dial-peer to provider is 702.
Você está usando H.323 entre CM e SBC? O peer de discagem 105 é um peer de discagem H.323.
dial-peer voice 105 voip
 description CUCM
 destination-pattern [89]...$
 session target ipv4:192.168.1.10
 voice-class codec 1
 voice-class h323 1
 voice-class sip dtmf-relay force rtp-nte
 dtmf-relay rtp-nte
 no vad
