cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
How many specific numbers can I block form incoming calls?
fabian-vargas
How many specific numbers can I block from incoming call with a Gateway Cisco?
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
If you are using reject statements in a voice translation profile, you can block up to 100 numbers because that is the maximum size of the rule list in a voice translation rule.
It is possible to block more than that using a policy document if you have a CUBE, but that is more advanced.
Does this help?
Maren
Ver la solución en mensaje original publicado
2 RESPUESTAS 2
Does this help?
Maren
fabian-vargas
Thank you very much for your response!!!
