Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Artificial Intelligence (AI) at the Edge by Alexander Stevenson, Cisco DevNet IoT Artificial Intelligence (AI) is often used as an umbrella term to describe intelligent agents that take inputs from their environment and attempt to achieve a cognitiv...
We are using a Kontakt.io Portal Beam as an occupancy sensor in Cisco Spaces, assigned to a room with occupancy type PEOPLE_COUNT. Our requirement is to receive a Firehose API event whenever room occupancy changes (0 → >0 and >0 → 0).We successfully ...
Hey,I have a catalyst 8300 router and I upgraded the code from 17.09.04a to 17.13.1a. Now my ubuntu kvm virtual service will not activate. I've uninstalled and attempted to reinstall the ova file, i even tried an earlier version i created that i kn...
IOS-XE Version: 26.01.01I'm running a Docker application under IOx on a Catalyst 8300. The application runs Plex Media Server and uses rclone to access an SMB share on a Synology NAS, then presents that share to Plex through a FUSE mount.This config...
Hi everyone,I'm trying to deploy a simple Go application as a Docker container on a Cisco C9120AX Access Point running IOS XE 17.15.5.36 I've been stuck on a deployment error and would appreciate any guidance.The ErrorWhen deploying my IOx package, ...
Hi, I am following the Getting Started with the API Sandbox page and the link for the Sandbox reservation does not work for me: https://devnetsandbox.cisco.com/RM/Diagram/Index/910a8c3c-0f85-4a9c-8d56-0000c1d4b497?diagramType=Topology
I’ve always thought Cisco was way ahead of the curve on this stuff because they understood early that logistics was eventually going to become a giant realtime data problem. Everybody focused on the “iot gadgets” part back then, but Cisco was looking...
Hi Team,I am unable to create docker image for the Cisco XRv 9000 Routers, IOS XR Release 25.4.1 in Containerized Lab(CLAB) server which is running Linux based on Red Hat Enterprise 9.4 as mentioned in release note link below, while I tried to create...
Hi,Is there some sort of internal ID on the CGR1k router which is unique for every router? I'm working on an application for GOS on CGR1k and need a unique ID on the router which I could read from the guest OS and bind a license to this ID.Thanks,Pav...
Since this happened to me, I thought I should share this.Messages like this appear constantly:*Feb 11 09:34:24.861: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/network-confg) failedThis is explained here:The user r...
I've got a problem with faulty timestamps from 1980-01-06 showing up in my timeline. It seems it has to do with the gateway not being able to fix its GPS and PPS. Is there anyone who has had experience with this? I'm using the IXM-LPWA-800-16-K9.
Hello, I am running a C1121X-8P with Cisco IOS XE Software, Version 17.09.03a. I am following this guide to host a simple nginx docker container on my router. Problem is that it fails verification even tho it is disabled funnyrouter#app-hosting verif...
I am atttempting to run a Linux VM in IOx on a C8200 platform. The container log shows that it is starting with option:-machine pc-0.13,accel=kvm,usb=off,dump-guest-core=offand complains:2025-10-21T17:11:14.773544Z qemu-kvm: Machine type 'pc-0.13' i...
Hello, experts!I'd like to test IOx application on Cisco ISR 4k, but faced a problem while generating IOx app with ioxclient from Cisco.The test stand is like this: VM with installed docker and ioxclient. Docker successfully downloads the images from...
