cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
7
Respuestas
1572 point to point bridge
Mike Vzz
hello experts on wireless
I have doubt?
I have 2 ap 1572 with antennas AIR-ANT2513P4M-N and cable AIR-CAB010LL-N= on both sides.
the both ap's have ios, c1570-k9w7-tar.153-3.JG1.tar
autonomus image
the ap 1572 have 4 ports for anntennas 1,2,3,4
tha antenna AIR-ANT2513P4M-N have 4 port a,b,c,d
I connected ap with antenna on the next position.
a1, b2 c3 d4
the distance is 2.03 km
the hight is 22 m
I want implement point to point (bridge) Root/non-root
I have output both side
Signal Strength : -67 dBm Signal to Noise : 29 dB
the messages ouput:
*May 24 22:16:11.579: %DOT11-7-AUTH_FAILED: Station a03d.6f56.c470 Authentication failed
*May 24 22:16:11.579: %DOT11-4-MAXRETRIES: Packet to client a03d.6f56.c470 reached max retries, removing the client
*May 24 22:16:16.191: %DOT11-4-MAXRETRIES: Packet to client a03d.6f56.c470 reached max retries, removing the client
*May 24 22:16:20.799: %DOT11-7-AUTH_FAILED: Station a03d.6f56.c470 Authentication failed
7 RESPUESTAS 7
Rafael E
Hi Mike,
That does not look like a problem with RF but a configuration problem.
What type of authentication are you using on the SSID?
Can you share both "show run" from APs?
Rafael - TAC
Saludos,
Rafael - TAC
hello  Rafael,
I shared the config  Non-root bridge
Hello Rafael
I share config Root bridge
Can you remove the "infrastructure-client" command from both AP and test again?
Rafael  - TAC
Saludos,
Rafael - TAC
Hello, Rafael
I did the config changes, but don't change anything.
hello dudes.
For this case point to point, the model 1570 with this antenna does not operate well for this distance just in band 5.0ghz. for another way on band 2.4 working very well. this implementation was done last year. I don't know if currently another version de ios that maybe give successfully for this case.
Thanks for your contributions and assistance @Mike Vzz
We take them into consideration and provide awards for people who collaborate ad assist others in the community
