cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
15
ÚTIL
6
Respuestas
AYUDA Air-lap1142n-a-k9
soporte_betoz
Hola todos
el problema: compre dos Air-lap1142n-a-k9 por internet y al querer configurarlos
en uno al querer ingresar por interfaz web que me arroja la ip ; accedo a la pag. que dice office Extend Access Point, pero al colocar el usuario y password de Cisco.
me aparece una mensaje de "The AP is not in FlexConnect mode"
y el otro ap no me deja ingresar a la pagina web, pero el switch le asigna ya una ip. por otro lado no me deja acceder en el CLI por EXEC privilegiado. solo me arroja estos comandos:
Exec commands:
access-profile Apply user-profile to interface
capwap capwap exec commands
cd Change current directory
clear Reset functions
clock Manage the system clock
crypto Encryption related commands.
debug Debugging functions (see also 'undebug')
delete Delete a file
dir List files on a filesystem
disable Turn off privileged commands
dot1x IEEE 802.1X Exec Commands
eap EAP Exec Commands
enable Turn on privileged commands
exit Exit from the EXEC
fsck Fsck a filesystem
help Description of the interactive help system
led LED functions
lock Lock the terminal
logging Handles logging operations
login Log in as a particular user
logout Exit from the EXEC
lwapconfig OfficeExtend AP configurations
lwapp lwapp exec commands
mkdir Create new directory
monitor Monitoring different system events
more Display the contents of a file
name-connection Name an existing network connection
no Disable debugging functions
partition Partition disk
ping Send echo messages
pwd Display current working directory
radius radius exec commands
release Release a resource
reload Halt and perform a cold restart
rename Rename a file
renew Renew a resource
rmdir Remove existing directory
rsh Execute a remote command
send Send a message to other tty lines
set Set system parameter (not config)
show Show running system information
ssh Open a secure shell client connection
systat Display information about terminal lines
terminal Set terminal line parameters
test Test subsystems, memory, and interfaces
traceroute Trace route to destination
undebug Disable debugging functions (see also 'debug')
upgrade Upgrade commands
verify Verify a file
where List active connections
cabe mencionar que ambos les di reset siguiendo estas indicaciones de este post:
https://community.cisco.com/t5/other-wireless-mobility-subjects/air-lap1142n-a-k9-factory-reset/m-p/2550592#M65264
que puede estar pasando
gracias anticipadas
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
Hola @soporte_betoz
Efevtivamente ambos equipos tienen una imagen dependendiente de Controladora "flash:/c1140-rcvk9w8-mx/c1140-rcvk9w8-mx" Tus equipos deberian de tener la igmagen 9w7.
Necesitas  descargar la imagen correcta para tu AP, tienes que elegir la versión Autonomous AP IOS Software, esa descarga la puedes realizar acá.  Es importante saber, que para poder acceder al área de descargas debe de contar con un contrato de mantenimiento con Cisco, en caso contrario no lo podrás descargar.
El proceso para la conversión lo puedes encontrar en este post. Esta respuesta la realice en foro global, si tienes problemas con algún paso o el idioma por favor, hazmelo saber y con gusto podré ayudarte.
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
*Tu reconocimiento nos alienta a seguir participando en los foros *
Ver la solución en mensaje original publicado
6 RESPUESTAS 6
Hola @soporte_betoz
Es probable que los equipos tengan una imagen dependiente de Controladora, es decir, necesitaras una Wireless Lan Controller para poder administrar y configurar tus APs.  Para estar seguro entra por el puerto de consola y compartenos el output del comando "show version"
Gracias @Daniel Ordóñez Flores aqui la informacion:
este es el ap que me dice:  The AP is not in FlexConnect mode.
APf#sh version
Cisco IOS Software, C1140 Software (C1140-K9W8-M), Version 15.2(2)JB1, RELEASE S OFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 07-May-13 09:14 by prod_rel_team
ROM: Bootstrap program is C1140 boot loader
BOOTLDR: C1140 Boot Loader (C1140-BOOT-M) Version 12.4(23c)JA3, RELEASE SOFTWARE (fc1)
AP uptime is 15 minutes
System image file is "flash:/c1140-k9w8-mx.152-2.JB1/c1140-k9w8-mx.152-2.JB1"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1142N-A-K9 (PowerPC405ex) processor (revision B0) with 81910K/49152K bytes of memory.
Processor board ID FTX1610K26U
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from power-on
LWAPP image version 7.4.100.60
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: F0:F7:55:19:62:6F
Part Number : 73-12836-04
PCA Assembly Number : 800-33767-04
PCA Revision Number : A0
PCB Serial Number : FOC16023
Top Assembly Part Number : 800-33775-03
Top Assembly Serial Number : FTX1610K
Top Revision Number : A0
Product/Model Number : AIR-LAP1142N-A-K9
Configuration register is 0xF
APf#
este es el otro :
#sh version
Cisco IOS Software, C1140 Software (C1140-RCVK9W8-M), Version 12.4(21a)JA, RELEA SE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 08-Jun-09 16:28 by prod_rel_team
APd48c.b561.21f4 uptime is 1 minute
System image file is "flash:/c1140-rcvk9w8-mx/c1140-rcvk9w8-mx"
export@cisco.com.
cisco AIR-LAP1142N-A-K9 (PowerPC405ex) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID FTX1629E16H
LWAPP image version 3.0.51.0
Base ethernet MAC Address: D4:8C:B5:61:22:F5
Part Number : 73-12836-05
PCA Assembly Number : 800-33767-05
PCB Serial Number : FOC6261
Top Assembly Part Number : 800-33775-04
Top Assembly Serial Number : FTX1629E
AP>
Gracias por el apoyo
Hola @soporte_betoz
gracias @Daniel Ordóñez Flores voy a intentar descargarla o buscarla y si tengo dudas busco como me comentas o te escribo.
agradezco tu ayuda tan oportuna.
Saludos
@soporte_betoz
Claro que si.
Saludos
Buenas,
Necesito la ios c1140-rcvk9w8-mx, ¿Algún link disponible?
