cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Can Cisco Flex 7500 controller replace 5508 WLC?
saudmalik
I have a client who is insisting to get 7500 series controller to deploy 350 APs initially in the campus and then move on to deploy branches globally.  I have a couple of questions regarding this:
1- I know there are some limitations in 7500 comparing with 5500 series, like it doesn't support Layer 3 roaming etc, Can I still deploy 350 AP in the same    campus keeping an SSID in one subnet for 2000 users, so there wont be any need of layer3 roaming?
2- Can I deploy more than one SSID and use different subnets as we do normally?
3- If we order 7500flex bundle AIR-CT7510-500-K9, does it come with 10Gig SFP 'SFP-10G-SR'?
4- Can I use this SFP-10G-SR to connect to normail GLC-SX-MM 1-gig?
5- I read it only runs HREAP APs, what about normal mode APs?
6- it says at cisco.com product site,  Other benefits of the Cisco Flex 7500 Series Controller include: Cisco Identity Services Engine for a single point of policy       across wired and wireless networks. Does it come bundles with ISE?
thanks
0 RESPUESTAS 0
