el 06-04-2013 09:12 PM
Wonder if anyone can help me. Trying to get a 3503i AP working with the newly relased Autonomous image. First I had issues with reaching it after installing. Could not ping from different subnets. After reading a blogposet here related 1200 series I ran NO IP ROUTING. It started working and I was able to connect via SSH , Web GUI of the AP.
Now I am faced with connecting clients to it. Clients receive IP s from central DHCP server. But they hang , it looks like they are trying to authenticate.
Below is showing up on AP
*Mar 1 00:29:17.426: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar 1 00:29:40.944: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 40a6.d98b.0a58 Associated KEY_MGMT[WPAv2 PSK]
Greatly appreciate if someone can help. Could it be another bug in the image ?
Config of the AP
Current configuration : 2923 bytes
! Last configuration change at 00:29:14 UTC Mon Mar 1 1993
version 15.2
no service pad
service password-encryption
hostname ap
logging rate-limit console 9
enable secret 5 $1$Rc9t$71qkC47romYdEyI8ECvxz.
no aaa new-model
no ip routing
no ip cef
ip name-server 10.0.0.2
dot11 syslog
dot11 ssid CGAF
vlan 325
authentication open
authentication key-management wpa version 2
mbssid guest-mode
wpa-psk ascii 7 06040237455D000D0A051C0E1810
username Cisco password 7 13261E010803
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 325 mode ciphers aes-ccm tkip
ssid CGAF
antenna gain 0
mbssid
station-role root
interface Dot11Radio0.300
encapsulation dot1Q 300 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.325
encapsulation dot1Q 325
no ip route-cache
bridge-group 255
bridge-group 255 subscriber-loop-control
bridge-group 255 spanning-disabled
bridge-group 255 block-unknown-source
no bridge-group 255 source-learning
no bridge-group 255 unicast-flooding
interface Dot11Radio1
no ip address
no ip route-cache
ssid CGAF
antenna gain 0
no dfs band block
mbssid
channel dfs
station-role root
interface Dot11Radio1.300
no ip route-cache
bridge-group 1
interface Dot11Radio1.325
no ip route-cache
bridge-group 255
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
interface GigabitEthernet0.300
no ip route-cache
bridge-group 1
interface GigabitEthernet0.325
no ip route-cache
bridge-group 255
interface BVI1
ip address 10.2.8.60 255.255.255.0
no ip route-cache
ip default-gateway 10.2.8.254
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
end
el 06-04-2013 11:29 PM
This means that the client has successfully associated.
Can you post the output to the command "sh dot11 assoc client 40a6.d98b.0a58 "?
el 06-04-2013 11:45 PM
This was seen after few minutes of that association
*Mar 1 03:34:29.266: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 40a6.d98b.0a58 Reason: Sending station has left the BSS
Also when ran the show command it wouldn't take the command with the MAC address , instead worked with interface
below is the output.
ap#sh dot11 assoc client interface dot11Radio 0
802.11 Client Stations on Dot11Radio0:
SSID [CGAF] :
MAC Address IP address Device Name Parent State
40a6.d98b.0a58 0.0.0.0 unknown - self Assoc
el 06-04-2013 11:46 PM
It doenst look like it's picking up IP s anymore.
Is the config done right ?
el 06-05-2013 12:03 AM
The link between your AP and the switch is a Dot1Q trunk with VLANs 300 & 325 allowed?
el 06-05-2013 12:05 AM
Yes , the switch is HP Procurve range.
I have port Untagged for VLAN 300 and tagged for VLAN 325. VLAN 300 is the native VLAN
el 06-04-2013 11:57 PM
Hi Aravind,
From the configuration perspective it is not a standard to use WPA2 and TKIP at the same time.
This should have been either WPA/TKIP or WPA2/AES combintation.
Try modifying your configuration as below.
config terminal
int dot11 radio 0
no encryption vlan 325 mode ciphers aes-ccm tkip
int dot11 radio 1
Hope that helps
Najaf
Please rate when applicable or helpful !!!
el 06-05-2013 12:01 AM
Thanks Najaf . Let me try. But I have other AP s 1131 model running autonomous has encryption set to AES CCMP + TKIP, working fine.
Config is same as this one , excpet this one is differnt AP model and newer image , plus the subnet and IP address of the AP device.
el 06-05-2013 12:07 AM
Hi Aravind,
This may or may not work for some clients :-)
You can find more details with below post.
https://supportforums.cisco.com/message/3669929#3669929
Hope that helps
Najaf
el 06-05-2013 04:55 PM
Thanks Najaf. I have seen this before. However I tried Just AES but no luck, still the same.
el 06-05-2013 06:58 PM
Hi Aravind,
Could you try a new SSID with out any wpa keys for testing purpose and verify if that works?
Hope that helps
Najaf
el 06-05-2013 08:44 PM
Najaf,
I have tried this already. Had tried with no authentication and no encryption. Still doing the same thing.
el 06-17-2013 09:20 PM
All,
Issue is fixed. Bug in IOS , by default IP ROUTING is enabled. Also had to re-do the DHCP scopes in MS DHCP server , which helped clients to associate. Guess there was a some sort of a bug in that too.
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
Navegue y encuentre contenido personalizado de la comunidad
