cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Not able to access Internet When connected with Guest SSID
lalitkumar88551
Not able to access Internet When connected with Guest SSID, Multiple users of multiple locations issue observed.
WLC5520
Product Version. 8.10.162.0
error log...
---------------Show msglog---------------
Message Log Severity Level ...................... ERROR
*dot1xMsgTask: Apr 07 04:44:44.963: %DOT1X-3-WPA_SEND_STATE_ERR: 1x_kxsm.c:1742 Unable to send EAPOL-key msg - invalid WPA state (0) - client
Previous message occurred 2 times.
Apr 07 04:23:22.873: [ERROR] ewmain.c 2969: EmWeb: select() failed for bad file descriptor : Bad file descriptor
Apr 07 04:02:40.927: [ERROR] ew_code.c 50522: current EMWEB_STRING/INCLUDE code did not return
Apr 07 04:02:40.927: Previous message occurred 11 times.
Apr 06 18:28:29.664: [ERROR] ewmain.c 2969: EmWeb: select() failed for bad file descriptor : Bad file descriptor
Apr 06 18:27:37.609: [ERROR] ew_code.c 50522: current EMWEB_STRING/INCLUDE code did not return
Apr 06 18:27:37.609: Previous message occurred 3 times.
Apr 06 14:27:25.489: [ERROR] ewmain.c 2969: EmWeb: select() failed for bad file descriptor : Bad file descriptor
*apfReceiveTask: Apr 06 13:57:28.649: %LOG-3-Q_IND: 1x_eapkey.c:3062 Received EAPOL-key message while in invalid state (4) - version 2, type 3, descriptor 2, client XX:XX:d3:c3:ec:35
*Dot1x_NW_MsgTask_5: Apr 06 13:53:42.541: %DOT1X-3-INVALID_WPA_KEY_STATE: 1x_eapkey.c:3062 Received EAPOL-key message while in invalid state (4) - version 2, type 3, descriptor 2, client 66:3d:d3:c3:ec:35
*Dot1x_NW_MsgTask_6: Apr 06 13:44:05.040: %LOG-3-Q_IND: 1x_eapkey.c:458 Invalid replay counter from client 00:42:38:dc:87:af - got 00 00 00 00 00 00 00 00, expected 00 00 00 00 00 00 00 01[...It occurred 2 times.!]
*Dot1x_NW_MsgTask_7: Apr 06 13:38:39.106: %DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:458 Invalid replay counter from client 00:42:38:dc:87:af - got 00 00 00 00 00 00 00 00, expected 00 00 00 00 00 00 00 01
*Dot1x_NW_MsgTask_4: Apr 06 13:07:38.983: %DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:458 Invalid replay counter from client c4:23:60:f8:29:4c - got 00 00 00 00 00 00 00 00, expected 00 00 00 00 00 00 00 01
*dot1xMsgTask: Apr 06 13:04:14.925: %DOT1X-3-WPA_SEND_STATE_ERR: 1x_kxsm.c:1742 Unable to send EAPOL-key msg - invalid WPA state (0) - client da:7a:11:ef:70:5d
*dot1xMsgTask: Apr 06 12:55:09.885: %DOT1X-3-WPA_SEND_STATE_ERR: 1x_kxsm.c:1742 Unable to send EAPOL-key msg - invalid WPA state (0) - client 6c:94:66:11:29:c0
*dot1xMsgTask: Apr 06 12:54:03.169: %DOT1X-3-WPA_SEND_STATE_ERR: 1x_kxsm.c:1742 Unable to send EAPOL-key msg - invalid WPA state (0) - client
*dot1xMsgTask: Apr 06 12:51:11.625: %DOT1X-3-WPA_SEND_STATE_ERR: 1x_kxsm.c:1742 Unable to send EAPOL-key msg - invalid WPA state (0) - client
*dot1xMsgTask: Apr 06 12:41:23.529: %DOT1X-3-WPA_SEND_STATE_ERR: 1x_kxsm.c:1742 Unable to send EAPOL-key msg - invalid WPA state (0) - client
*dot1xMsgTask: Apr 06 12:35:08.721: %DOT1X-3-WPA_SEND_STATE_ERR: 1x_kxsm.c:1742 Unable to send EAPOL-key msg - invalid WPA state (0) - client
1 RESPUESTA 1
Forget about this log.
Can you take on failing  client and run the command:
ipconfig /all
nslookup www.google.com
and share here?
