cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Position Wireless access point 3502E
gregory_loiseau
I bought AIR-CAP3502E-EK910 wireless access point
How I should orient the antennas in the two following cases
- wall
- ceiling
Do you have any photos ?
Thx
Greg
1 RESPUESTA 1
Leo Laohoo
Depends on the type of antennas you're going to use.
If my antennas are rubber duck/rubber duckies then it would be good if the antennas are pointing towards the floor.  If you have the articulated antennas of the above-mentioned varieties then you can mount the WAP on the and bend the antennas to point to the floor.
However, if you have the patch antennas then you will need to ensure you go through the signal pattern to know whether the antenna needs to be patched on the wall, ceiling or pole.
