cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Wireless Client Connecting at Slower Linkrate Than Capable to my 881W ISR
jaesposito
All,
I have a wireless client (MAC Address:  c43d.c7a9.4917) that is connecting to my wireless VLAN at a slower linkrate (56Mbps) than is desired.  The
wireless client is 802.11n version 2.0 capable, which means that it is capable at connecting at a higher linkrate even though it can only run at 2.4Ghz.
With this in mind, I have two questions:
1.)  Does the current Aironet configuration on my 881W integrated device allow for this wireless client to connect at a higher linkrate?
2.)  If not, what configuration changes should I make in order to allow this device to connect at a higher linkrate?
Attached is a copy of my "show config" from the Aironet (801) side of my 881W ISR as well as the output of a "show dot11 assocations c43d.c7a9.4917" for the wireless client of interest.
Please advise.  Thanks.
James E
0 RESPUESTAS 0
