My 6509 device, the following high temperature message appears. I don’t know how to troubleshoot this problem.
Please guide
Mod Ports Card Type Model Serial No.
1 24 CEF720 24 port 1000mb SFP WS-X6724-SFP SAL14017LN6
5 20 Supervisor Engine 6T 10GE w/ CTS (Acti C6800-SUP6T JAE25151BXY
8 40 DCEF2T 8 port 40GE / 32 port 10GE C6800-32P10G JAE253100ZE
Mod MAC addresses Hw Fw Sw Status
1 c47d.4fc0.47e8 to c47d.4fc0.47ff 4.3 12.2(18r)S1 15.5(1)SY6 Ok
5 6c03.09c1.f42b to 6c03.09c1.f439 2.1 15.3(04r)SYS 15.5(1)SY6 Ok
8 f04a.0232.0a90 to f04a.0232.0ab7 2.2 15.2(1r)SYL3 15.5(1)SY6 MinFail
Mod Sub-Module Model Serial Hw Status
1 Distributed Forwarding Card WS-F6K-DFC4-A SAL1749HGDV 2.0 Ok
5 Policy Feature Card 4 C6800-PFC JAE25151B35 1.0 Ok
8 Distributed Forwarding Card C6800-DFC JAE253100ZE 2.2 MinFail
8 Distributed Forwarding Card C6800-DFC JAE2531003K 2.1 MinFail
system minor alarm on module 8 device-2 temperature (raised 00:40:20 ago)
backplane: operating clock count: 2
operating VTT count: 3
operating fan count: 1
fan-tray 1:
fan-tray 1 type: WS-C6509-E-FAN
fan-tray 1 mode: High-power
fan-tray 1 fan-fail: OK
VTT 1:
VTT 1 OK: OK
VTT 1 outlet temperature: 32C
VTT 2:
VTT 2 OK: OK
VTT 2 outlet temperature: 26C
VTT 3:
VTT 3 OK: OK
VTT 3 outlet temperature: 30C
clock 1:
clock 1 OK: OK, clock 1 clock-inuse: in-use
clock 2:
clock 2 OK: OK, clock 2 clock-inuse: not-in-use
power-supply 1:
power-supply 1 fan-fail: OK
power-supply 1 power-input: AC high
power-supply 1 power-output-mode: high
power-supply 1 incompatible with fan: OK
power-supply 1 power-output-fail: OK
power-supply 2:
power-supply 2 fan-fail: OK
power-supply 2 power-input: AC high
power-supply 2 power-output-mode: high
power-supply 2 incompatible with fan: OK
power-supply 2 power-output-fail: OK
module 1:
module 1 power-output-fail: OK
module 1 outlet temperature: 23C
module 1 inlet temperature: 26C
module 1 device-1 temperature: 32C
module 1 device-2 temperature: 26C
module 1 EARL outlet temperature: 35C
module 1 EARL inlet temperature: 30C
module 5:
module 5 power-output-fail: OK
module 5 module outlet-1 temperature: 22C
module 5 module inlet-1 temperature: 22C
module 5 module outlet-2 temperature: 41C
module 5 module inlet-2 temperature: 42C
module 5 asic-1 temperature: 47C
module 5 asic-2 temperature: 72C
module 5 asic-3 temperature: 52C
module 5 EARL outlet-1 temperature: 96C
module 5 EARL inlet-1 temperature: 95C
module 8:
module 8 power-output-fail: OK
module 8 outlet temperature: 35C
module 8 inlet temperature: 26C
module 8 device-1 temperature: 55C
module 8 device-2 temperature: 50C
module 8 aux-1 temperature: 43C
module 8 aux-2 temperature: 45C
module 8 asic-1 temperature: 55C
module 8 asic-2 temperature: 55C
module 8 asic-3 temperature: 56C
module 8 asic-4 temperature: 58C
module 8 EARL device-1 temperature: 79C
module 8 EARL device-2 temperature: 73C
module 8 EARL device-1 temperature: 73C
module 8 EARL device-2 temperature: 72C
Frank
Check the output of "show environment alarm thresholds switch 1 module x" command and you will see the minor and major alarm thersholds. if the value that you are seeing is with in that range you should be good.
