custom.ribbon_feed
取消
显示结果
搜索替代
您的意思是:
查看次数
18
有帮助
回复
在日志中产生大量的%SYS-SP-3-CPUHOG信息process = SEA write CF process,其原因...
iosvip_163_com
请教下论坛大咖,在日志中产生大量的%SYS-SP-3-CPUHOG信息,其原因?当前设备运行正常。
设备类型:c6509
设备版本:12.22(33)
产生大量如下日志信息(部分):
Log Buffer (262144 bytes):
mpAlarm(OFF), minorAlarm(ON), and/or majorAlarm(OFF)
May 20 19:08:44 beijing: %C6KPWR-SP-4-PSREDUNDANTONESUPPLY: in power-redundancy mode, system is operating on one power supply.
May 20 19:08:51 beijing: %SNMP-5-CHASSISALARM: Chassis Alarm Trap: tmpAlarm(OFF), minorAlarm(OFF), and/or majorAlarm(OFF)
May 20 19:08:50 beijing: %C6KPWR-SP-4-PSOK: power supply 1 turned on.
May 20 19:08:51 beijing: %C6KPWR-SP-4-PSREDUNDANTBOTHSUPPLY: in power-redundancy mode, system is operating on both power supplies.
May 20 19:08:55 beijing: %C6KPWR-SP-2-PSFAIL: power supply 1 output failed.
-Traceback= 40FCB6D8 40FCD710 40FCD61C 40FEDEC8 40FED31C 40FEDDDC 40EAF574 40EA5BB0 40EB0C6C 40EB0F0C 40EA657C 40E9B048 40E9B1A8 40E9A588 40E98B50 40EB3CD8
May 22 08:17:46 beijing: %SYS-SP-3-CPUHOG: Task is running for (2000)msecs, more than (2000)msecs (5/5),process = SEA write CF process.
-Traceback= 40FCC230 40FCB728 40FCD710 40FCD61C 40FEDEC8 40FED31C 40FEDDDC 40EAF590 40EA5BB0 40EB0C6C 40EB0F0C 40EA657C 40E9B048 40E9B1A8 40E9A588 40E98B50
May 22 08:17:50 beijing: %SYS-SP-3-CPUHOG: Task is running for (2000)msecs, more than (2000)msecs (1/1),process = SEA write CF process.
-Traceback= 40FEDFE8 40FED31C 40FEDDDC 40EAF590 40EA5D88 40EB0C6C 40EB0F0C 40EA6654 40E9B048 40E9B1A8 40E9A588 40E98B50 40EB3CD8 404E701C 41060E34 41062274
May 22 08:27:44 beijing: %SYS-SP-3-CPUHOG: Task is running for (2000)msecs, more than (2000)msecs (7/7),process = SEA write CF process.
-Traceback= 40FCD60C 40FEDEC8 40FED31C 40FEDD90 40EAF4DC 40EA5CB0 40EB2ED4 40EB25B8 40EA62DC 40EA5578 40EA4080 40E9A5C0 40E98ED0 40EB3DA0 404E7480 41060DC8
May 22 08:27:46 beijing: %SYS-SP-3-CPUHOG: Task is running for (2000)msecs, more than (2000)msecs (1/1),process = SEA write CF process.
May 22 08:27:48 beijing: %SYS-SP-3-CPUHOG: Task is running for (2000)msecs, more than (2000)msecs (3/3),process = SEA write CF process.
1 个已接受解答
已接受的解答
Walter.wu
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCsg85415
参考这个BUG信息,在保设备可以联系思科TAC,帮忙确认解决。
非在保设备,找供应商提供版本,准备窗口时间进行设备升级解决。
Cisco CCIE EI /CCNP DC
Vmware VCP
PMP
CISSP
在原帖中查看解决方案
4 条回复4
Walter.wu
Vmware VCP
PMP
CISSP
Walter.wu
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuh80510
还一个BUG信息在这里。
供参考,可以确认的是SYS-SP-3-CPUHOG:,process = SEA write CF process.这些是BUG导致的。
就看TAC介入后,帮忙确认是哪个具体的BUG信息了
Vmware VCP
PMP
CISSP
iosvip_163_com
还一个BUG信息在这里。
供参考,可以确认的 ...
非常感谢您的支持,设备差不多是8年前的,代理商未知,如果需要补丁是否还有其他渠道。为谢!
Walter.wu
可以根据你当前设备的引擎版本,硬件信息,查找当前思科推荐版本进行升级。
https://software.cisco.com/download/home/270638920
你可以进去查看当前硬件设备型号,依据型号进行查找版本。
Vmware VCP
PMP
CISSP
快捷链接
