取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
cisco 4507R VFE Module temperature is too high.
xiaojiang
Mar 17 13:46:56.918: %C4K_IOSMODPORTMAN-4-MODULETEMPHIGH: Module 3 Sensor VFE temperature is at or over threshold - CurrentTemp: 79C, Threshold: 79C 发动机:模块3传感器VFE温度处于或超过阈值-CurrentTemp: 79C,阈值79C
The module temperature of the CPU module is also too high
The temperature of the power module is too high
But CPU usage is also low
At present, there should be too much dust. I intend to clean up the dust. Is there any dismantling process or better solution
thank you
1 个已接受解答
已接受的解答
如果的确发现设备的板卡,挡板,尤其是进出风口比较多灰尘的话,还是先建议清灰。
这个log的建议也是找出根本的原因,鉴于没有发现其他的问题,可以先尝试清灰看看。
Error Message    C4K_IOSMODPORTMAN-4-MODULETEMPHIGH: Module [dec] Sensor [char]
temperature is at  or over threshold - CurrentTemp: [dec]C, Threshold: [dec]C
Explanation    The module temperature is above its threshold. If the temperature goes above critical threshold, another message will be logged and the system will shut down to prevent damage to hardware.
Recommended Action    Inspect the module and find out why it is heating up.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/50sg/system/messages/errbk/emsg.html
相关模块的Guide,可以参考如下:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/hardware/catalyst4500e/installation/guide/Eseries/04replac.html?bookSearch=true
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/hardware/configuration/notes/OL_29676.html
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
在原帖中查看解决方案
2 条回复2
相关模块的Guide,可以参考如下:
好的  谢谢
快捷链接
