I have one question about L3 multicast
I have many multicast source input to Switch;
we detected the all of TS multicast stream PCR continuous count error by stream analyzer;
I check Switch logging that having one port down-up causes this problem,
In the test environment, I tested the down-up of G1 port ,about one minute later, I received multicast stream from G2 port which detected PCR error by stream analyzer.
Is this normal? Is there any way to fix this? Thanks.
CISCO Switch Catalyst 3650 version 16.3.6
The config is that :
interface GigabitEthernet0/0/1
no switchport
ip address 10.101.20.1 255.255.255.252
ip pim passive
interface GigabitEthernet0/0/2
no switchport
ip address 10.101.20.5 255.255.255.252
ip pim passive
interface TenGigabitEthernet0/0/1
no switchport
ip address 172.168.2.1 255.255.255.252
ip pim sparse-mode
ip igmp static-group 239.0.100.1
ip igmp static-group 239.0.200.1
interface LoopBack0
ip address 192.1.1.1 255.255.255.255
ip pim sparse-mode
ip pim rp-address 192.1.1.1 override
