取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
cisco3650恢复密码后,光纤模块和对端的3750 端口down掉出现功率报错
Nikone
Jul 25 15:43:30.877: %SFF8472-5-THRESHOLD_VIOLATION: Gi1/0/49: Tx power low alarm; Operating value: -40.0 dBm, Threshold value: -10.5 dBm. Jul 25 15:43:31.398: %SFF8472-5-THRESHOLD_VIOLATION: Gi1/0/50: Tx power low alarm; Operating value: -40.0 dBm, Threshold value: -10.5 dBm.
有人有类似经验吗?
4 条回复4
可以输入命令"show int Gi1/0/49 transceiver detail" 和 "show int Gi1/0/50 transceiver detail" 看看两个光口的实际详细情况。
除此外,是否有再出现报错之后,执行过重启、更换光模块、插拔光线之类的操作。
之前也有遇到过,通过升级/升级到稳定版本后解决问题的。
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
ITA-MILAN-CORE1#show int Gi1/0/49 transceiver detai
ITU Channel not available (Wavelength not available),
Transceiver is internally calibrated.
mA: milliamperes, dBm: decibels (milliwatts), NA or N/A: not applicable.
++ : high alarm, + : high warning, - : low warning, -- : low alarm.
A2D readouts (if they differ), are reported in parentheses.
The threshold values are calibrated.
High Alarm High Warn Low Warn Low Alarm
Temperature Threshold Threshold Threshold Threshold
Port (Celsius) (Celsius) (Celsius) (Celsius) (Celsius)
Gi1/0/49 25.6 90.0 85.0 -40.0 -45.0
Voltage Threshold Threshold Threshold Threshold
Port (Volts) (Volts) (Volts) (Volts) (Volts)
Gi1/0/49 3.26 3.79 3.46 3.13 2.80
Optical High Alarm High Warn Low Warn Low Alarm
Transmit Power Threshold Threshold Threshold Threshold
Port (dBm) (dBm) (dBm) (dBm) (dBm)
Gi1/0/49 -40.0 -- -1.5 -2.0 -10.0 -10.5
Receive Power Threshold Threshold Threshold Threshold
Gi1/0/49 -11.0 -1.5 -2.0 -19.0 -19.5
ITA-MILAN-CORE1#show int Gi1/0/50 transceiver detail
Gi1/0/50 24.9 90.0 85.0 -40.0 -45.0
Gi1/0/50 3.25 3.79 3.46 3.13 2.80
Gi1/0/50 -40.0 -- -1.5 -2.0 -10.0 -10.5
Gi1/0/50 -6.6 -1.5 -2.0 -19.0 -19.5
就是因为重启过设备,因为要实施恢复密码操作,其他的没有操作,而且在发现光模块无法up的时候,就没有保存修改,再次重启本以为恢复原状后,可以恢复。但是仍然是down的状态。所以又再次重启破解了密码,至少可以登录进去查看状态。
Cisco IOS Software, C3560 Software (C3560-IPBASEK9-M), Version 15.0(2)SE11, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Sat 19-Aug-17 09:21 by prod_rel_team
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SEE4, RELEASE SOFTWARE (fc1)
ITA-SWPCS01 uptime is 15 hours, 49 minutes
System image file is "flash:/c3560-ipbasek9-mz.150-2.SE11.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3560G-24PS (PowerPC405) processor (revision F0) with 131072K bytes of memory.
Processor board ID FOC1110Y36X
Last reset from power-on
4 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:1B:53:88:D3:00
Motherboard assembly number : 73-10213-04
Power supply part number : 341-0108-03
Motherboard serial number : FOC11093Z9D
Power supply serial number : DCA1106A2EL
Model revision number : F0
Motherboard revision number : B0
Model number : WS-C3560G-24PS-S
System serial number : FOC1110Y36X
Top Assembly Part Number : 800-26847-01
Top Assembly Revision Number : B0
Version ID : V05
CLEI Code Number : CNMW100ARC
Hardware Board Revision Number : 0x09
Switch Ports Model SW Version SW Image
* 1 28 WS-C3560G-24PS 15.0(2)SE11 C3560-IPBASEK9-M
Configuration register is 0xF
再看一下这些信息呢:
  • show ip int br
  • show interface Gi1/0/49
  • show interface Gi1/0/50
  • show interface Gi1/0/49 status
  • show interface Gi1/0/50 status
  • show interface status
  • show errdisable recovery
  • show logg
  • show run | i vio
  • show run | i err
Rockyw
@Nikone 你可以参考一下社区的这个帖子:
已解决: %SFF8472-5-THRESHOLD_VIOLATION: RX
https://community.cisco.com/t5/switching/sff8472-5-threshold-violation-rx/td-p/2690210
或者下面的文档
SFP+ complains threshold violation and went down
https://networkengineering.stackexchange.com/questions/10807/sfp-complains-threshold-violation-and-went-down
Rockyw | If it solves your problem, please mark as answer. Thanks !
快捷链接
