取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
Smart Licensing到期后会如何
adu102501
客户并无打算使用DNA架构
9200及9300型号,Firmware 16.9版以后,Smart License若无法到思科网站或CSSM,会显示EVAL MODE以及倒数90天
请问超过90天后Smart Licensing 无法启用的话会如何
因为思科目前推荐的Firmware皆为16.9以后,且16.6以前的Firmware会陆续EoL,故不考虑使用16.6以前Firmware的情形
Switch#show license all
Smart Licensing Status
Smart Licensing is ENABLED
Registration:
Status: UNREGISTERED
Export-Controlled Functionality: NOT ALLOWED
License Authorization:
Status: EVAL MODE
Evaluation Period Remaining: 89 days, 23 hours, 58 minutes, 13 seconds
Export Authorization Key:
Features Authorized:
Utility:
Status: DISABLED
Data Privacy:
Sending Hostname: yes
Callhome hostname privacy: DISABLED
Smart Licensing hostname privacy: DISABLED
Version privacy: DISABLED
Transport:
Type: Callhome
License Usage
(C9300-24 DNA Essentials):
Description:
Count: 1
Version: 1.0
Status: EVAL MODE
Export status: NOT RESTRICTED
(C9300-24 Network Essentials):
Description:
Count: 1
Version: 1.0
Status: EVAL MODE
Product Information
1 个已接受解答
已接受的解答
l8310892118l
我们公司的9407R就是使用Smart License激活了的。因为某些原因没有购买正式的network advantage license。现在已经到期了,暂时没有出现问题。之前咨询过渠道,他们说现阶段(意思是以后不知道会怎么样),到期了之后功能也全部是可以用的,并且设备可以任意重启,没有任何影响。
===============下面是当前设备的sho license all ===============
C9407R#sho license all
Registration:
Status: UNREGISTERED - REGISTRATION FAILED
Export-Controlled Functionality: Not Allowed
Initial Registration: FAILED on
Failure reason: The product regid.2017-05.com.cisco.C9400,v1_ad928212-d182-407e-ac85-29e213602efa and sudi containing udiSerialNumber:FXS2302Q2JB,udiPid:C9407R has already been registered.
Status: EVAL EXPIRED
Utility:
Status: DISABLED
Data Privacy:
Transport:
Type: Callhome
License Usage
(dna_essentials-C9400):
Description:
Count: 2
Version: 1.0
(advantagek9-C9400):
Description:
Count: 2
Version: 1.0
Product Information
UDI: PID:C9407R,SN:FXS2302Q2JB
HA UDI List:
Active:PID:C9407R,SN:FXS2302Q2JB
Standby:PID:C9407R,SN:FXS2302Q4D2
Agent Version
Smart Agent for Licensing: 4.5.6_rel/12
Component Versions: SA:(1_3_dev)1.0.15, SI:(dev22)1.2.1, CH:(rel5)1.0.3, PK:(dev18)1.0.3
Reservation Info
License reservation: DISABLED
在原帖中查看解决方案
2 条回复2
l8310892118l
Registration:
Utility:
Status: DISABLED
Data Privacy:
Transport:
Type: Callhome
License Usage
Description:
Count: 2
Version: 1.0
Description:
Count: 2
Version: 1.0
Product Information
HA UDI List:
Agent Version
Reservation Info
adu102501
找到原厂文件如下
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9500-series-switches/214484-cisco-smart-licensing-troubleshooting.html
When the evaluation period expires at the end of 90 days, the device goes in to EVAL EXPIRY mode, however there is no functional impact or disruption in functionality, even after reload. Currently there is no enforcement in place.
跟楼上说的一样
快捷链接
