取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
AnyConnect was not able to establish a connection to the specified
Holaway
AnyConnect was not able to establish a connection to the specified secure gateway. Please try connecting againHolaway_0-1666229026330.png
1 个已接受解答
已接受的解答
I have solved the problem,I did this by configuring a command on the ASA firewall.
ASA-FW(config)#ssl encryption aes256-sha1 aes128-sha1
在原帖中查看解决方案
2 条回复2
balaji.bandi
check the logs on ASA , looking like authentication failing as per informaiton.
BB
快捷链接
