取消
显示结果
搜索替代
您的意思是:
查看次数
15
有帮助
38
评论
ilay
一、环境准备
  1. 下载EWC所需的文件,本文使用的是:C9800-AP-universalk9.16.12.04a.zip
    Software Download - Cisco Systems
  2. 解压文件到tftp目录或者sftp的目录
    PS D:\Share\C9800-AP-universalk9.16.12.04a> ls
      Directory: D:\Share\C9800-AP-universalk9.16.12.04a
    Mode                 LastWriteTime         Length Name
    -----           2020/8/1     2:37       37488640 ap1g4
    -----           2020/8/1     2:37       35676160 ap1g5
    -----           2020/8/1     2:37       57487360 ap1g6
    -----           2020/8/1     2:37       60057600 ap1g6a
    -----           2020/8/1     2:37       64675840 ap1g7
    -----           2020/8/1     2:37       52613120 ap3g3
    -----           2020/8/1   13:11     224913440 C9800-AP-iosxe-wlc.bin
    -----           2020/8/1   13:11             13 controller_version.info
    -----           2020/8/1   13:11           354 readme.txt
    -----           2020/8/1     2:37             11 version.info
  3. 检查镜像文件,连接准备升级的AP。本次使用的是Catalyst9120 AXI的AP,查看解压后目录中"readme.txt"可以发现9120使用的是ap1g7的镜像文件
  4. 要求及注意事项:
    The prerequisites for deploying an EWC network are as follows:
    ● You must not have other Cisco wireless controllers, neither appliance nor virtual, in the same network, during the setup or daily operation of a Cisco EWC network.(升级EWC过程中,网络内不要有其他的控制器)//保证ewc不能发现controller即可
    ● An EWC network is supported in the same Layer 2 domain. (在同一个二层网络中配置EWC)
    ● Configure a Dynamic Host Configuration Protocol (DHCP) server on the switch or externally so that Cisco Catalyst 9100 Access Points can obtain an IP address at bootup. The DHCP server also assigns IP addresses to other APs and wireless clients.(配置一个dhcp)//可选配置,有dhcp可以省点事儿
    ● The DHCP server should provide default gateway and DNS server IP addresses. (如果配置dhcp,需要提供默认网关和dns的配置)
    ● If the network is made up of different AP models, you need to set a Trivial FTP (TFTP) server that can be accessed from the management interface of the EWC. Save the C9800-AP-univesalk9<version>.zip file (unzipped) on the TFTP server.(如果网络中有不同的网络型号,需要将zip包中的镜像放到tftp的目录中)
    ● Decide on the first AP to set up. This AP must support Cisco EWC functionality. You can also connect multiple Cisco Catalyst 9100 Access Points running the EWC to the switch.(决定使用哪一个ap作为第一个EWC AP,可以连接多个运行EWC的ap到交换机上)//想不太懂后面有啥含义,配置ewc的时候还是先搞定这一台
    ● You will need a Wi-Fi-enabled laptop to connect to the predefined CiscoAirProvision-<last 4 digits of AP-MAC> SSID for provisioning and configuring the EWC. Alternatively, you can use a mobile device or tablet with the Cisco Catalyst Wireless application installed to configure and provision the EWC.(你需要一台支持wifi的笔记本,或者使用手机,连接到CiscoAirProvision-xxxx的ssid上 xxxx是 AP的后4位MAC)//设置过程中可以不用,没啥用,有可能出坑
    ● If you intend to use 802.1X authentication, you need to have a RADIUS/Authentication, Authorization, and Accounting (AAA) server.(如果要使用802.1x认证,需要有一个radius)
    ● All APs joining to EWC network should have minimum of 8.10.X or 16.12.X code.(加入到EWC的ap需要满足镜像的最低版本要求)
二、升级步骤
升级使用的9120是一个注册在控制器上的瘦AP,使用ap-type ewc-ap tftp://TFTP_PATH/ap1g7 tftp://TFTP_PATH/C9800-AP-iosxe-wlc.bin 也可使用sftp替代tftp加快传输的速度
ap-type ewc-ap sftp://10.0.2.96/home/ilay/ap1g7 sftp://10.0.2.96/home/ilay/C9800-AP-iosxe-wlc.bin
SD_AP_TEST-01#
SD_AP_TEST-01#ap-type ewc-ap sftp://10.0.2.96/home/ilay/ap1g7 sftp://10.0.2.96/home/ilay/C9800-AP-iosxe-wlc.bin
Starting download eWLC image sftp://10.0.2.96/home/ilay/C9800-AP-iosxe-wlc.bin ... <--- 开始下载eWLC的镜像
It may take a few minutes. If longer, please abort command, check network and try again.
Please enter SFTP credentials ...
Username: ilay                                                           <--- 按照提示输入sftp的用户名密码
######################################################################## 100.0%
Checking ...OK
Checking image size...OK
Verifying ...OK
Versioning ...ws_management_version: 16.12.04a.0.9
Successfully downloaded and setup eWLC image.
Starting download AP image sftp://10.0.2.96/home/ilay/ap1g7 ...   <--- 下载ap的镜像
Username: ilay
Upgrading ...
upgrade.sh: Script called with args:[NO_UPGRADE]
do NO_UPGRADE, part1 is active part
upgrade.sh: Script called with args:[-c PREDOWNLOAD]
do PREDOWNLOAD, part1 is active part
upgrade.sh: Start doing upgrade arg1=PREDOWNLOAD arg2=,from_cli arg3= ...
upgrade.sh: Using image /tmp/cli_part.tar on axel-bcm ...
Image signing verify success.
[5/20/2021 2:13:26] : Shadow is now in-synced with master
[5/20/2021 2:13:26] : Verifying against bundle image btldr.img...
upgrade.sh: part to upgrade is part2
upgrade.sh: AP version1: part2 8.10.121.0, img 16.12.4.31
upgrade.sh: Untar /tmp/cli_part.tar to /bootpart/part2...
upgrade.sh: Sync image to disk...
upgrade.sh: AP version2: part2 16.12.4.31, img 16.12.4.31
upgrade.sh: AP backup version: 16.12.4.31
upgrade.sh: Finished upgrade task.
upgrade.sh: Cleanup for do_upgrade...
upgrade.sh: /tmp/upgrade_in_progress cleaned
upgrade.sh: Cleanup tmp files ...
upgrade.sh: Script called with args:[ACTIVATE]
do ACTIVATE, part1 is active part
upgrade.sh: activate part2, set BOOT to part2
upgrade.sh: AP primary version after reload: 16.12.4.31
upgrade.sh: AP backup version after reload: 8.10.130.0
Successfully setup AP image.
Archive done.                                                     <--- 镜像升级完成
SD_AP_TEST-01#[*05/20/2021 02:12:52.1340] Config Factory Reset triggered: clear saved config files.. <--- AP和eWLC的镜像升级完成,自动重启系统
[*05/20/2021 02:12:52.2130]
[*05/20/2021 02:12:52.2130] CAPWAP State: DTLS TeardownDropping dtls packet since session is not established. Peer 10.1.1x.xx-5246, Local 10.1.30.251-5260, conn (nil)
[*05/20/2021 02:12:52.2430] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP st         Stopping Serial Getty on ttyS0...
        Stopping Fast CGI daemon...
        Stopping Cisco led service...
---- 省略部分重启过程的输出内容-------------
三、EWC初始化踩坑阶段
交换机侧配置:
TEST-PoE#sh run int g1/0/1  //vlan30没有dhcp,需要手动配置ip地址
Building configuration...
Current configuration : 94 bytes
interface GigabitEthernet1/0/1
switchport trunk native vlan 30
switchport mode trunk
end
TEST-PoE#
第一坑:
Installation mode is BUNDLE
        --- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]: no
Num of cpu cores     4
Maximum number of AP's supported   100
Would you like to terminate autoinstall? [yes]:
Failed to generate persistent self-signed certificate.
  Secure server will use temporary self-signed certificate.
Press RETURN to get started!
*May 20 02:16:30.834: %PNP-6-PNP_SAVING_TECH_SUMMARY: Saving PnP tech summary (pnp-tech-discovery-summary)... Please wait. Do not interrupt.
*May 20 02:16:31.045: %SYS-5-CONFIG_P: Configured programmatically by process Setup from console as vty0
*May 20 02:16:32.194: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: CISCO_IDEVID_SUDI_LEGACY created succesfully
*May 20 02:16:32.226: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named CISCO_IDEVID_SUDI_LEGACY has been generated or imported by pki-sudi
*May 20 02:16:32.299: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: CISCO_IDEVID_SUDI_LEGACY0 created succesfully
*May 20 02:16:32.763: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: CISCO_IDEVID_SUDI created succesfully
*May 20 02:16:32.791: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named CISCO_IDEVID_SUDI has been generated or imported by pki-sudi
*May 20 02:16:32.915: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: CISCO_IDEVID_SUDI0 created succesfully
*May 20 02:16:33.782: %SYS-5-CONFIG_P: Configured programmatically by process PnP Agent Discovery from console as vty0
*May 20 02:16:35.367: %SYS-5-CONFIG_P: Configured programmatically by process PnP Agent Discovery from console as vty0
*May 20 02:16:36.367: %PNP-6-PNP_TECH_SUMMARY_SAVED_OK: PnP tech summary (pnp-tech-discovery-summary) saved successfully.
*May 20 02:16:36.368: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Config Wizard)
*May 20 02:16:38.077: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-2458377709 has been generated or imported by crypto-engine
*May 20 02:16:38.083: %SSH-5-ENABLED: SSH 1.99 has been enabled
*May 20 02:16:38.225: %PKI-4-NOCONFIGAUTOSAVE: Configuration was modified. Issue "write memory" to save new IOS PKI configuration
*May 20 02:16:38.767: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-2458377709.server has been generated or imported by crypto-engine
*May 20 02:16:52.766: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: SLA-TrustPoint created succesfully
*May 20 02:16:52.774: %PKI-4-NOCONFIGAUTOSAVE: Configuration was modified. Issue "write memory" to save new IOS PKI configuration
*May 20 02:16:52.776: %SMART_LIC-6-EXPORT_CONTROLLED: Usage of export controlled features is not allowed
*May 20 02:16:52.795: %CALL_HOME-6-CALL_HOME_ENABLED: Call-home is enabled by Smart Agent for Licensing.
WLC>en
WLC#conf t
Enter configuration commands, one per line. End with CNTL/Z.
WLC(config)#user-name admin               <--- 设置用户名密码用于登录webui,需要给15级权限
WLC(config-user-name)#privilege 15
WLC(config-user-name)#sec
WLC(config-user-name)#secret Abc@1234
WLC(config-user-name)#exit
WLC(config)#int g0
WLC(config-if)#ip add 10.1.30.251 255.255.255.0     <--- 设置g0口ip地址作为管理地址使用
WLC(config-if)#exit
WLC(config)#ip default-ga 10.1.30.2
WLC(config)#end
WLC#ping 10.1.30.2
Sending 5, 100-byte ICMP Echos to 10.1.30.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
WLC#wireless ewc-ap ap shell     <--- 进入ap的 cli,配置ip地址,ap和ewc公用一个物理接口,需要ap的接口先能通信后,ewc配置的ip地址才能通
The authenticity of host '192.168.129.1 (192.168.129.1)' can't be established.
RSA key fingerprint is 7b:66:27:44:0c:63:52:4e:51:60:03:1c:f3:17:58:26.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added '192.168.129.1' (RSA) to the list of known hosts.
Cisco@192.168.129.1's password:   <--- 初始的密码时Cisco ,enable也是Cisco
APA488.EEEE.788C>en
Password:
APA488.EEEE.788C#capwap ap ip 10.1.30.252 255.255.255.0 10.1.30.2   <--- AP手动设置ip地址
APA488.EEEE.788C#ping 10.1.30.2                                     <--- ping 网关测试,到网关正常
Success rate is 100 percent (5/5), round-trip min/avg/max = 2.120/5.121/15.248 ms
APA488.EEEE.788C#
APA488.EEEE.788C#exit                                               <--- 退出ap模式,返回ewlc的cli
Connection to 192.168.129.1 closed.
WLC#ping 10.1.30.2                               <--- 坑来了,wlc ping网关是不通的,shut/no shut接口也是不管用的,wr, reload也不好用
WLC#sh run int g0
Current configuration : 201 bytes
interface GigabitEthernet0
mac-address 0000.5e00.0101
ip dhcp client client-id GigabitEthernet0
ip dhcp client broadcast-flag clear
ip address 10.1.30.251 255.255.255.0
no negotiation auto
end
第二坑:
将交换机接口的native VLAN更改到一个有dhcp server的网段,switchport trunk native vlan 10,同时EWC erase startup-config后reload
Num of cpu cores     4
nono
% Please answer 'yes' or 'no'.
Would you like to terminate autoinstall? [yes]: yes
*May 20 02:45:19.873: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-2458377709 has been generated or imported by crypto-engine
*May 20 02:45:19.879: %SSH-5-ENABLED: SSH 1.99 has been enabled
*May 20 02:45:20.028: %PKI-4-NOCONFIGAUTOSAVE: Configuration was modified. Issue "write memory" to save new IOS PKI configuration
*May 20 02:45:20.044: %SYS-5-CONFIG_P: Configured programmatically by process Setup from console as vty0
*May 20 02:45:20.731: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-2458377709.server has been generated or imported by crypto-engine
*May 20 02:45:21.578: %PNP-6-PNP_SAVING_TECH_SUMMARY: Saving PnP tech summary (pnp-tech-discovery-summary)... Please wait. Do not interrupt.
*May 20 02:45:22.991: %SYS-5-CONFIG_P: Configured programmatically by process PnP Agent Discovery from console as vty0
*May 20 02:45:24.005: %SYS-5-CONFIG_P: Configured programmatically by process PnP Agent Discovery from console as vty0
*May 20 02:45:25.025: %SYS-5-CONFIG_P: Configured programmatically by process PnP Agent Discovery from console as vty0
WLC>
*May 20 02:45:26.520: %SYS-5-CONFIG_P: Configured programmatically by process PnP Agent Discovery from console as vty0
*May 20 02:45:27.524: %PNP-6-PNP_TECH_SUMMARY_SAVED_OK: PnP tech summary (pnp-tech-discovery-summary) saved successfully.
*May 20 02:45:27.524: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Config Wizard)
WLC>
WLC>en
WLC#sh ip int b
Interface             IP-Address     OK? Method Status               Protocol
GigabitEthernet0       unassigned     YES DHCP   up                   up
WLC#s
*May 20 02:45:40.796: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: SLA-TrustPoint created succesfully
*May 20 02:45:40.805: %PKI-4-NOCONFIGAUTOSAVE: Configuration was modified. Issue "write memory" to save new IOS PKI configuration
*May 20 02:45:40.806: %SMART_LIC-6-EXPORT_CONTROLLED: Usage of export controlled features is not allowedh ip
*May 20 02:45:40.864: %CALL_HOME-6-CALL_HOME_ENABLED: Call-home is enabled by Smart Agent for Lice
WLC#sh run
Current configuration : 8137 bytes
! Last configuration change at 02:45:26 UTC Thu May 20 2021
version 16.12
no service pad
! Call-home is enabled by Smart-Licensing.
service call-home
no platform punt-keepalive disable-kernel-core
no platform punt-keepalive settings
platform console serial
hostname WLC
boot-start-marker
boot-end-marker
no aaa new-model
no fips authorization-key
call-home
! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
active
destination transport-method http
no destination transport-method email
login on-success log
crypto pki trustpoint TP-self-signed-2458377709
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2458377709
revocation-check none
rsakeypair TP-self-signed-2458377709
crypto pki trustpoint SLA-TrustPoint
enrollment pkcs12
revocation-check crl
crypto pki certificate chain TP-self-signed-2458377709
certificate self-signed 01
30820330 30820218 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32343538 33373737 3039301E 170D3231 30353230 30323435
31395A17 0D333030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 34353833
37373730 39308201 22300D06 092A8648 86F70D01 01010500 0382010F 00308201
0A028201 0100A62D E0180A44 8B9FB6F9 D830EA69 44993FDD CAAD3E2A 41E7A969
2DDC7AF0 7E4209CF 5B05EEA0 D4423C15 4F52A0D8 EDDB0727 DAA55500 63F42634
43FF2847 824A7FB7 569BB96F C3504A40 FCF91A73 092BA72B EB1EC0E5 687E0390
6393D8AD 9455E3C8 AC7E2974 C9AFDC7C 1C1D70EB F20B9105 B2D5434F 74474AD4
F8A81D2A DF6C5850 19BF08CF 8930F0D3 93E3A6DB FE372C17 DBD45BB2 92C18825
8CEC4EA5 19C7D8A1 2822B0DF 2475F53C 11B146AA EF9E73DA 5AB79015 E16F6C37
66F5E0BB 95B3F6A5 33AAFB6F 6F36A360 BE95A282 752C2751 3A1F1CEA C47B86E0
E1EA6F31 6E9BC31E B11C9068 9F419CF4 BFCB74B3 C0AA3C6E 9FC27BE9 D6D640BC
95A2A09C AB730203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF
301F0603 551D2304 18301680 14C4BC95 938D1300 892D3325 7CF85B13 049C61D0
F1301D06 03551D0E 04160414 C4BC9593 8D130089 2D33257C F85B1304 9C61D0F1
300D0609 2A864886 F70D0101 05050003 82010100 69B0CE7E 3E597871 F1791ECD
ECC7E3C0 B7050926 A38B5721 8A3BA42D 8C462EE7 BE1FE48D 47E29CAE 6177D84E
9A377C56 0CAE6201 70BDB47C CA5AF2F0 1858524B 1CB06EBE 842F4C6A C1098B9E
AC99960C 01277937 05F12775 836C40E9 4A0D7C69 03CCF988 4C71D4F4 7C74D695
BB5BA3A4 EC36D71D 1E0BB7C7 56F199CA 0BBE4D9D 70F4E3CE D8E55E2C EDA9AD35
D26370A8 112150C4 4894555C 603B6913 CEC1F8F3 618CDBA4 E0F76E10 C40F905D
E11F696F 07E46177 7E92F48F DCACF71F EF121CEF EACA6B32 D046C364 58AECCCA
377CFA9F E421D98C 9B36AA76 6A51C968 976889BD 3988CFA3 C5CCB42E 2E798873
2C0AECC4 4FB0DDE0 EB021B81 55CBEEAD AB8EDBB7
      quit
crypto pki certificate chain SLA-TrustPoint
certificate ca 01
30820321 30820209 A0030201 02020101 300D0609 2A864886 F70D0101 0B050030
32310E30 0C060355 040A1305 43697363 6F312030 1E060355 04031317 43697363
6F204C69 63656E73 696E6720 526F6F74 20434130 1E170D31 33303533 30313934
3834375A 170D3338 30353330 31393438 34375A30 32310E30 0C060355 040A1305
43697363 6F312030 1E060355 04031317 43697363 6F204C69 63656E73 696E6720
526F6F74 20434130 82012230 0D06092A 864886F7 0D010101 05000382 010F0030
82010A02 82010100 A6BCBD96 131E05F7 145EA72C 2CD686E6 17222EA1 F1EFF64D
CBB4C798 212AA147 C655D8D7 9471380D 8711441E 1AAF071A 9CAE6388 8A38E520
1C394D78 462EF239 C659F715 B98C0A59 5BBB5CBD 0CFEBEA3 700A8BF7 D8F256EE
4AA4E80D DB6FD1C9 60B1FD18 FFC69C96 6FA68957 A2617DE7 104FDC5F EA2956AC
7390A3EB 2B5436AD C847A2C5 DAB553EB 69A9A535 58E9F3E3 C0BD23CF 58BD7188
68E69491 20F320E7 948E71D7 AE3BCC84 F10684C7 4BC8E00F 539BA42B 42C68BB7
C7479096 B4CB2D62 EA2F505D C7B062A4 6811D95B E8250FC4 5D5D5FB8 8F27D191
C55F0D76 61F9A4CD 3D992327 A8BB03BD 4E6D7069 7CBADF8B DF5F4368 95135E44
DFC7C6CF 04DD7FD1 02030100 01A34230 40300E06 03551D0F 0101FF04 04030201
06300F06 03551D13 0101FF04 05300301 01FF301D 0603551D 0E041604 1449DC85
4B3D31E5 1B3E6A17 606AF333 3D3B4C73 E8300D06 092A8648 86F70D01 010B0500
03820101 00507F24 D3932A66 86025D9F E838AE5C 6D4DF6B0 49631C78 240DA905
604EDCDE FF4FED2B 77FC460E CD636FDB DD44681E 3A5673AB 9093D3B1 6C9E3D8B
D98987BF E40CBD9E 1AECA0C2 2189BB5C 8FA85686 CD98B646 5575B146 8DFC66A8
467A3DF4 4D565700 6ADF0F0D CF835015 3C04FF7C 21E878AC 11BA9CD2 55A9232C
7CA7B7E6 C1AF74F6 152E99B7 B1FCF9BB E973DE7F 5BDDEB86 C71E3B49 1765308B
5FB0DA06 B92AFE7F 494E8A9E 07B85737 F3A58BE1 1A48A229 C37C1E69 39F08678
80DDCD16 D6BACECA EEBC7CF9 8428787B 35202CDC 60E4616A B623CDBD 230E3AFB
418616A9 4093E049 4D10AB75 27E86F73 932E35B5 8862FDAE 0275156F 719BB2F0
D697DF7F 28
      quit
memory free low-watermark processor 33020
license udi pid C9800-AP sn FGLXX36XXXX
redundancy
mode sso
no ip address
no negotiation auto
ip http server
ip http authentication local
ip http secure-server
ip forward-protocol nd
ip tftp source-interface GigabitEthernet0
control-plane
line con 0
stopbits 1
line vty 0 4
login
line vty 5 15
login
wireless aaa policy default-aaa-policy
wireless cts-sxp profile default-sxp-profile
no wireless ipv6 ra wired
WLC#conf t
WLC(config)#int g0
WLC(config-if)#ip address dhcp     <--- 手动又敲了一遍 ip add dhcp 然后接口获取到地址
WLC(config-if)#end
WLC#sh ip int b
WLC#
*May 20 02:46:37.452: %SYS-5-CONFIG_I: Configured from console by console
*May 20 02:46:46.189: %DHCP-6-ADDRESS_ASSIGN: Interface GigabitEthernet0 assigned DHCP address 10.1.10.200, mask 255.255.255.0, hostname
WLC#ping 10.1.10.2
Sending 5, 100-byte ICMP Echos to 10.1.10.2, timeout is 2 seconds:
WLC#sh ip int b     <--- ping网关不通,检查接口状况
GigabitEthernet0       10.1.10.200   YES DHCP   up                   up
WLC#wireless ewc-ap ap shell   <--- 切换进ap的cli测试,ping网关是正常的
APA488.EEEE.788C>en
Password:
APA488.EEEE.788C#sh ip int b
Interface           IP-Address     Method   Status                 Protocol   Speed     Duplex
wired0               10.1.10.201   DHCP     up                     up         1000       full
apphostintf1         unassigned     unset   up                     up         n/a       n/a
apr0v0               n/a             n/a     administatively down   down       n/a       n/a
apr1v0               n/a             n/a     administatively down   down       n/a       n/a
APA488.EEEE.788C#
APA488.EEEE.788C#ping 10.1.10.2
Success rate is 100 percent (5/5), round-trip min/avg/max = 2.542/9.465/31.377 ms
APA488.EEEE.788C#ping 10.1.10.200
Sending 5, 100-byte ICMP Echos to 10.1.10.200, timeout is 2 seconds
Success rate is 0 percent (0/5),
WLC#conf t
WLC(config)#int g0
WLC(config-if)#shut
WLC(config-if)#no shut
WLC(config-if)#Converting VRRP MAC from string to hex
WLC(config-if)#
*May 20 02:48:38.132: %DHCP-6-ADDRESS_ASSIGN: Interface GigabitEthernet0 assigned DHCP address 10.1.10.200, mask 255.255.255.0, hostname
ping 10.1.10.2
% Invalid input detected at '^' marker.
WLC(config-if)#end
WLC#ping 10.1.10.2
*May 20 02:48:46.980: %SYS-5-CONFIG_I: Configured from console by console
WLC#
WLC#
WLC#sh arp
Protocol Address         Age (min) Hardware Addr   Type   Interface
Internet 10.1.10.2             0   Incomplete     ARPA
Internet 10.1.10.200           -   0000.5e00.0101 ARPA   GigabitEthernet0
WLC#
WLC#conf t
WLC(config)#int g0
WLC(config-if)#ip add 10.1.10.20 255.255.255.0
WLC(config-if)#shut
WLC(config-if)#no
*May 20 02:50:04.236: %LINK-5-CHANGED: Interface GigabitEthernet0, changed state to administratively down shut
*May 20 02:50:05.236: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*May 20 02:50:06.597: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
WLC(config-if)#
WLC(config-if)#end
WLC#sh ip int b
*May 20 02:50:18.323: %SYS-5-CONFIG_I: Configured from console by console
GigabitEthernet0       10.1.10.20     YES manual up                   up
WLC#ping 10.1.10.2                         <--- 手动配置了地址之后,再测试还是不行,在核心交换机上有arp条目,ewlc没有arp
WLC#
WLC# wireless ewc-ap factory-reset <--- 终极解决办法:执行day0重置,敲完之后自动重启
四、CLI初始化
执行wireless ewc-ap factory-reset后,ap重启,交换机改回之前的native vlan 30,没有dhcp server自动分配地址
Num of cpu cores     4
%Default route without gateway, if not a point-to-point interface, may impact performance
*May 20 03:14:49.452: %SYS-5-CONFIG_P: Configured programmatically by process Setup from console as vty0
#     Welcome to the Cisco Catalyst 9800-AP Embedded Wireless Controller command line interface       #
#                     !!! Please complete the DAY0 Device Provisioning !!!                           #
#                   !!! NOTE: COMPLETE ALL THE STEPS IN PROVISIONING GUIDE !!!                         #
#                     To access the provisioning guide type the below command:                         #
#                         more bootflash:ewc_day0_device_provisioning_guide                           #
WLCA488.EEEE.788C>       <---执行 factory-reset之后多了个banner的提示,默认的hostname也变成了WLC+MAC地址的格式,之前hostname只是WLC
WLCA488.EEEE.788C>
WLCA488.EEEE.788C>
*May 20 03:14:56.991: %PNP-6-PNP_SAVING_TECH_SUMMARY: Saving PnP tech summary (pnp-tech-discovery-summary)... Please wait. Do not interrupt.
*May 20 03:14:58.413: %SYS-5-CONFIG_P: Configured programmatically by process PnP Agent Discovery from console as vty0
*May 20 03:14:59.426: %SYS-5-CONFIG_P: Configured programmatically by process PnP Agent Discovery from console as vty0
*May 20 03:15:00.434: %SYS-5-CONFIG_P: Configured programmatically by process PnP Agent Discovery from console as vty0
WLCA488.EEEE.788C>
*May 20 03:15:01.852: %SYS-5-CONFIG_P: Configured programmatically by process PnP Agent Discovery from console as vty0
*May 20 03:15:02.853: %PNP-6-PNP_TECH_SUMMARY_SAVED_OK: PnP tech summary (pnp-tech-discovery-summary) saved successfully.
*May 20 03:15:02.853: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Config Wizard)
WLCA488.EEEE.788C>
WLCA488.EEEE.788C>en
WLCA488.EEEE.788C#sh run int g0
no negotiation auto
end
WLCA488.EEEE.788C#conf t
WLCA488.EEEE.788C(config)#int g0
WLCA488.EEEE.788C(config-if)#ip add 10.1.30.251 255.255.255.0
WLCA488.EEEE.788C(config-if)#exit                       <--- 手动设置 g0ip地址后,EWC的ap的那一部分自动disjoin了
*May 20 03:15:30.691: %CAPWAPAC_SMGR_TRACE_MESSAGE-5-AP_JOIN_DISJOIN: Chassis 1 R0/0: wncd: AP Event: AP Name: APA488.EEEE.788C, MAC: a488.EEEE.788c Disjoined
*May 20 03:15:30.706: %CAPWAP_IMGDWNLD_TRACE_MESSAGE-5-CAPWAPIMGDWNLD_EWC_AP_AP_LIST_EVENTS: Chassis 1 R0/0: wncd: List Event: AP with wtp_mac a488.738d.c460 for Image Type ap1g7 is removed from Master AP list
WLCA488.EEEE.788C(config)#ip route 0.0.0.0 0.0.0.0 10.1.30.2
WLCA488.EEEE.788C(config)#host
WLCA488.EEEE.788C(config)#hostname TEST-EWC
TEST-EWC(config)#
TEST-EWC(config)#
TEST-EWC(config)#user-name admin         <--- 创建privilege 15的账户,'username admin privilege 15 sec Abc@1234' 的命令也可以用
TEST-EWC(config-user-name)#pri
TEST-EWC(config-user-name)#privilege 15
TEST-EWC(config-user-name)#sec Abc@1234
TEST-EWC(config-user-name)#exit
TEST-EWC(config)#end
TEST-EWC#ping 10.1.30.2                               <--- AP的地址还有没设置,EWC到网关暂时不通
TEST-EWC#
TEST-EWC#wireless ewc-ap ap shell
RSA key fingerprint is cf:8f:87:7d:7b:d2:b7:42:4a:cb:e8:82:d4:a5:2c:9e.
APA488.EEEE.788C>en
Password:
APA488.EEEE.788C#
APA488.EEEE.788C#capwap ap ip 10.1.30.252 255.255.255.0 10.1.30.2   <--- ap手动配置静态ip地址
APA488.EEEE.788C#
APA488.EEEE.788C#ping 10.1.30.2                                     <--- 验证到网关的通信
Success rate is 100 percent (5/5), round-trip min/avg/max = 1.260/4.170/14.275 ms
TEST-EWC#ping 10.1.30.2                                           <--- 再次验证EWC到网关的通信,结果正常
Success rate is 100 percent (5/5), round-trip min/avg/max = 2/16/46 ms
TEST-EWC#
*May 20 03:21:20.325: %CAPWAP_IMGDWNLD_TRACE_MESSAGE-5-CAPWAPIMGDWNLD_EWC_AP_AP_LIST_EVENTS: Chassis 1 R0/0: wncd: List Event: AP with wtp_mac a488.738d.c460 for Image Type ap1g7 is added to Master AP list
*May 20 03:21:20.375: %APMGR_TRACE_MESSAGE-4-EWLC_APMGR_WARNING_MSG: Chassis 1 R0/0: wncd: Warning, AP APA488.EEEE.788C is associated with the policy tag default-policy-tag, which has no wlan or rlan configured. Please configure wlan or rlan under the policy tag, or associate the AP with valid policy tag
*May 20 03:21:20.441: %CAPWAPAC_SMGR_TRACE_MESSAGE-5-AP_JOIN_DISJOIN: Chassis 1 R0/0: wncd: AP Event: AP Name: APA488.EEEE.788C, MAC: a488.EEEE.788c Joined                   <--- AP重新join到EWC上
*May 20 03:21:32.097: %WEBSERVER-5-LOGIN_PASSED: Chassis 1 R0/0: nginx: Login Successful from host 10.1.10.158 by user 'admin' using crypto cipher 'ECDHE-RSA-AES128-GCM-SHA256' <--- WEBUI 登录也正常,浏览器访问https://mgmt-ip-address 输入前面创建的用户名密码即可
TEST-EWC#
TEST-EWC(config)#
TEST-EWC(config)#ap profile default-ap-profile <--- 设置ap的管理用户名密码
TEST-EWC(config-ap-profile)#mgmtuser username admin pass
TEST-EWC(config-ap-profile)#mgmtuser username admin password 0 Abc@1234 sec 0 Abc@1234
TEST-EWC(config-ap-profile)#exit
TEST-EWC(config)#
TEST-EWC(config)#wireless profile image-download default <--- 设置无线ap的镜像下载路径,EWC的闪存空间有限,如果EWC需要注册多个型号的ap需要设置一下
TEST-EWC(config-wireless-image-download-profile)#image-download-mode ?
cco     Configure image download using CCO
http   Configure image download using HTTP
http-s Configure image download using HTTPS
sftp   Configure image download using SFTP
tftp   Configure image download using TFTP
TEST-EWC(config-wireless-image-download-profile)#image-download-mode tftp
TEST-EWC(config-wireless-image-download-profile-tftp)#tftp-image-server 10.0.2.90
TEST-EWC(config-wireless-image-download-profile-tftp)#tftp-image-path /c9800-ap-img/
TEST-EWC(config-wireless-image-download-profile-tftp)#end
TEST-EWC#wr
五 其他问题
  • 进入WEBUI后,可以选择"Configuration"-"Wireless Setup" 选择使用Basic或Advanced的向导设置无线配置
  • AAA的配置可以通过CLI也可通过WEBUI配置,最初如果提示Would you like to enter the initial configuration dialog? [yes/no]:选择yes时,使用向导创建的 AAA的配置文件比较长,有强迫症的可能选择手动配置来解决此问题
  • 关于使用CiscoAirProvision-xxxx这个无线SSID来初始化EWC的方式,在这里并没有提到,向导模式的操作,问题应该不大。有一个小坑在这里提及一下,我在测试的时候将AP连接到办公网中,办公网连接互联网需要进行web认证,获取到的dns也是公司内部的。这时候连接CiscoAirProvision-xxxx这个信号进行初始化时,访问https://mgmt-ip-address 时,会重定向到"mywifi.cisco.com" ,web浏览器提示需要进行网络认证,认证的页面又被劫持成'mywifi.cisco.com',反复跳转。
    解决办法: 在CLI里面先执行以下wr,保存配置,然后敲"no ip name-server " 将默认的dns服务器(ip name-server 208.67.222.222 208.67.220.220)删掉,这样再通过ip地址访问的时候应该不会有什么问题了。
  • 将EWC的ap恢复成瘦AP的方法
    TEST-EWC#wireless ewc-ap ap shell username admin  <--- ap profile default-ap-profile中设置mgmtuser之后,在切换到ap的时候需要指定username,否则默认使用Cisco
    admin@192.168.129.1's password:
    EWC-TEST-AP-01>en
    Password:
    EWC-TEST-AP-01#ap-type capwap <--- 此命令执行后将ap重置为capwap的模式,作为瘦ap使用。命令执行后自动重启
因个人能力有限,如有错误之处还请大家帮指正,谢谢。
附:
参考链接1:Cisco Embedded Wireless Controller on Catalyst Access Points - Cisco Embedded Wireless Controller on Catalyst Access Points (EWC) White Paper - Cisco
参考链接2:Embedded Wireless Controller Conversion on Catalyst 9100 Access Points - Cisco
附件为此篇文档的markdown文件,将txt后缀删掉即可改回markdown文件
评论
dawnccier
@ilay 尝试过的办法:
1. EWC下 wireless ewc-ap factory-reset
重启后hostname并没有出现 WLC+MAC, 仍然是WLC。然后从新配置 IP还是网关不通,甚至ping自己的IP地址也不通。
2.转到AP模式后,相同子网下配置capwap IP后,确认可以ping通网关后,logout AP模式到EWC后,仍然ping不通自己和网关地址。
3.使用mode按钮重置AP后,依然不通。
4.EWC模式下删除backup镜像,转到AP模式,依然出现“image upgrade not needed, changing ap type to ewc-ap”
ilay
@dawnccier 按照我之前折腾的情况,不是WLC+MAC地址的主机名配置就是会有问题。
还能想到的一个办法就是用WLC将9120的镜像刷一下,先从backup_image中删除EWC的镜像,然后从vWLC或者C9800CL更新一下,最后再找个版本刷ewc
你说的第4条这个还真没测试过,你用的那个版本号,节后可以搞搞测试看看
另外vrrp的ip,从正常的设备上看show run all | in vrrp 只有一条“wireless ewc-ap vrrp vrid 1”的输出,你可以对比检查一下。
vrrp-ip.txt的文件在 config:目录下,但是copy不出来,暂时不知道里面是什么内容
EWC_TEST# dir all-filesystems
Directory of config:/
662     drwx              920  Sep 30 2021 19:18:39 +08:00  bootflash6
661     -rwx             7864  Aug 23 2021 22:35:30 +08:00  bootflash3
660     -rwx          2097152  Aug 23 2021 22:32:10 +08:00  bootflash2
5894    -rw-             8938  Aug 23 2021 22:32:06 +08:00  bootflash2_bkup_210723_143206.gz
697     -rwx              266  Aug 23 2021 22:25:02 +08:00  vrrp-ip.txt
695     -rwx                8  Jul 29 2021 10:32:13 +08:00  ewc_def_air_lic_state.dat
5650    drwx              648  Jul 29 2021 09:50:38 +08:00  .ssh
664     drwx              536   Jun 9 2021 10:26:03 +08:00  bootflash8
665     drwx              160   Jun 9 2021 10:24:40 +08:00  bootflash9
663     drwx              160   Jun 9 2021 10:24:40 +08:00  bootflash7
@dawnccier 你好,你那个情况弄个外置的DHCP,再重启一下ewc就可以了。
@ilay 你好,我遇到和他相同的问题,使用wireless ewc-ap ap shell转到AP模式,出现“image upgrade not needed, changing ap type to ewc-ap”,而且我的
WLC84F1.47B3.8E70#dir backup_image:
Directory of backup_image:/
No files in directory
545398784 bytes total (421040128 bytes free)
backup_image:/这个文件夹是没有文件的,请问我如何使用cli来升级这个ewc呢?
当前版本是Cisco IOS Software [Bengaluru], C9800-AP Software (C9800-AP-K9_IOSXE-UNIVERSALK9-M), Version 17.6.1, RELEASE SOFTWARE (fc6),想降级到16.12.4a或者升级到17.6.1b,使用cli,请大神赐教!!!!
ilay
719823809@qq.com
backup_image中没有文件表示你的ewc只有一个primary image啊,升级过一次之后backup_image中就有东西了
controller升级最好用GUI啊,点几下就好了。
CLI升级镜像的步骤:
1.将对应的的zip包下载,解压(目录需包含9800镜像及所需ap的镜像文件)
2.配置 ap download profile //因9120的flash空间较小,ap的image通常存在外部,之前的path是17.3.4的现在直接修改为17.5.1的文件路径即可(我这只修改了tftp-image-path,如果没有的这个配置的话,补全即可)
  description "default image download profile"
  tftp-image-path /c9800-img-17-5-1/
3.执行controller image和ap image的预下载,并按照提示重启
EWC_TEST#install add profile ?
WORD Profile name (Max 15 chars, specify default to trigger default
behaviour)
EWC_TEST#install add profile default
install_add: START Fri Oct 8 16:51:33 CST 2021
Downloading file tftp://10.0.2.90//c9800-img-17-5-1/C9800-AP-iosxe-wlc.bin
Oct 8 08:51:34.266: %INSTALL-5-INSTALL_START_INFO: Chassis 1 R0/0: install_engine: Started install add
Oct 8 08:53:48.808: %SEC_LOGIN-5-LOGIN_SUCCESS: Login Success [user: admin] [Source: 10.1.17.158] [localport: 22] at 16:53:48 CST Fri Oct 8 2021Finished downloading file tftp://10.0.2.90//c9800-img-17-5-1/C9800-AP-iosxe-wlc.bin to backup_image:C9800-AP-iosxe-wlc.bin
install_add: Adding PACKAGE
install_add: Checking whether new add is allowed ....
--- Starting initial file syncing ---
Info: Finished copying backup_image:C9800-AP-iosxe-wlc.bin to the selected chassis
Finished initial file syncing
--- Starting Add ---
Performing Add on all members
[1] Add package(s) on chassis 1/R0
[1] Finished Add on chassis 1/R0
Checking status of Add on [1/R0]
Add: Passed on [1/R0]
Finished Add
Image added. Version: 17.05.01.0.144
SUCCESS: install_add Fri Oct 8 16:54:45 CST 2021
EWC_TEST#
Oct 8 08:54:45.812: %INSTALL-5-INSTALL_COMPLETED_INFO: Chassis 1 R0/0: install_engine: Completed install add PACKAGE backup_image:C9800-AP-iosxe-wlc.bin
Oct 8 08:54:50.376: %INSTALL-5-INSTALL_START_INFO: Chassis 1 R0/0: install_engine: Started install add tftp://10.0.2.90//c9800-img-17-5-1/controller_version.info
Oct 8 08:54:52.177: %INSTALL-5-INSTALL_COMPLETED_INFO: Chassis 1 R0/0: install_engine: Completed install add tftp://10.0.2.90//c9800-img-17-5-1/controller_version.info
Oct 8 08:54:56.682: %INSTALL-5-INSTALL_START_INFO: Chassis 1 R0/0: install_engine: Started install add tftp://10.0.2.90//c9800-img-17-5-1/version.info
Oct 8 08:54:58.459: %INSTALL-5-INSTALL_COMPLETED_INFO: Chassis 1 R0/0: install_engine: Completed install add tftp://10.0.2.90//c9800-img-17-5-1/version.info
Oct 8 08:55:02.975: %INSTALL-5-INSTALL_START_INFO: Chassis 1 R0/0: install_engine: Started install add tftp://10.0.2.90//c9800-img-17-5-1/ap1g7
Oct 8 08:55:39.710: %INSTALL-5-INSTALL_COMPLETED_INFO: Chassis 1 R0/0: install_engine: Completed install add tftp://10.0.2.90//c9800-img-17-5-1/ap1g7
Oct 8 08:57:46.021: %CAPWAP_IMGDWNLD_TRACE_MESSAGE-6-CAPWAPIMGDWNLD_EWC_AP_AP_IMAGE_DELETED: Chassis 1 R0/0: wncd: AP Event: Downloaded AP image ap1g7 was deleted
EWC_TEST#dir back
EWC_TEST#dir backup_image:
56899 -rw- 10 Oct 8 2021 16:54:57 +08:00 version.info
56897 -rw- 14 Oct 8 2021 16:54:51 +08:00 controller_version.info
56643 -rw- 267715612 Oct 8 2021 16:53:41 +08:00 C9800-AP-iosxe-wlc.bin
545398784 bytes total (138678272 bytes free)
EWC_TEST#install ac
EWC_TEST#install activate ?
auto-abort-timer Set the abort timer
file Specify package to activate
profile Specify profile to actiavte
prompt-level Set the prompt level
<cr> <cr>
install_activate: START Fri Oct 8 16:59:19 CST 2021
install_activate: Activating PACKAGE
Oct 8 08:59:21.061: %INSTALL-5-INSTALL_START_INFO: Chassis 1 R0/0: install_engine: Started install activate
This operation requires a reload of the system. Do you want to proceed? [y/n]y
--- Starting Activate ---
Performing Activate on all members
[1] Activate package(s) on chassis 1/R0
[1] Finished Activate on chassis 1/R0
Checking status of Activate on [1/R0]
Activate: Passed on [1/R0]
Finished Activate
Oct 8 09:00:21.799: %CAPWAP_IMGDWNLD_TRACE_MESSAGE-6-CAPWAPIMGDWNLD_EWC_AP_SEND_MASTER_GOING_DOWN: Chassis 1 R0/0: wncd: Sending master-going-down message to other APs so that they backoff for 5 minutes for existing active controller to be active after reload
Send model notification for install_activate before reload
Install will reload the system now!
SUCCESS: install_activate Fri Oct 8 17:01:14 CST 2021
4. 重启之后检查系统版本等等
EWC_TEST#show install summary
[ Chassis 1/R0 ] Installed Package(s) Information:
State (St): I - Inactive, U - Activated & Uncommitted,
C - Activated & Committed, D - Deactivated & Uncommitted
Type St Filename/Version
IMG U 17.05.01.0.144
Auto abort timer: inactive
EWC_TEST# install commit
install_commit: START Fri Oct 8 17:11:51 CST 2021
install_commit: Committing PACKAGE
--- Starting Commit ---
Performing Commit on all members
Oct 8 09:11:52.563: %INSTALL-5-INSTALL_START_INFO: Chassis 1 R0/0: install_engine: Started install commit [1] Commit package(s) on chassis 1/R0
[1] Finished Commit on chassis 1/R0
Checking status of Commit on [1/R0]
Commit: Passed on [1/R0]
Finished Commit
SUCCESS: install_commit Fri Oct 8 17:11:58 CST 2021
EWC_TEST#
Oct 8 09:11:59.424: %INSTALL-5-INSTALL_COMPLETED_INFO: Chassis 1 R0/0: install_engine: Completed install commit PACKAGE
EWC_TEST# dir backup_image:
56941 -rw- 240595996 Oct 8 2021 17:03:41 +08:00 C9800-AP-iosxe-wlc.bin  //重启之后会将原来的primary_image移至 backup_image中
545398784 bytes total (165167104 bytes free)
EWC_TEST#
参考链接:https://www.cisco.com/c/en/us/td/docs/wireless/controller/ewc/16-12/config-guide/ewc_cg_16_12/image_download.html#id_129497
@ilay 你好,我的这个又出现新问题了,如下:
WLC8#install add pro default
install_add: START Sat Oct 9 08:48:45 UTC 2021
Oct 9 08:48:46.378: %INSTALL-5-INSTALL_START_INFO: Chassis 1 R0/0: install_engine: Started install addFAILED: install_add : Default profile addition failed due to no response from wireless side
WLC8#
Oct 9 08:48:57.485: %INSTALL-3-OPERATION_ERROR_MESSAGE: Chassis 1 R0/0: install_engine: Failed to install_add package , Error: install_add : Default profile addition failed due to no response from wireless side
WLC8#
WLC8#
WLC8#
WLC8#show run | s wireless profile
wireless profile airtime-fairness default-atf-policy 0
wireless profile flex default-flex-profile
description "default flex profile"
tftp-image-path /Tftpd64/
tftp-image-server 192.168.1.10
wireless profile mesh default-mesh-profile
description "default mesh profile"
@ilay
还有你那个路径是怎么设置的:
我用的是tftp64,ewc和ap的镜像是放在tftp64的根目录下面的,不知道问题出在哪里?你的这个"/c9800-img-17-5-1/"是镜像文件的父目录吗?
ilay
719823809@qq.com
根目录的话直接写/ 就可以了,我的是解压到了tftp根下的一个目录,因为有多个版本,所以每个版本都搞了个目录来区分
+--- c9800-img-16-12-04a
|   +--- ap1g4
|   +--- ap1g5
|   +--- ap1g6
|   +--- ap1g6a
|   +--- ap1g7
|   +--- ap3g3
|   +--- C9800-AP-iosxe-wlc.bin
|   +--- controller_version.info
|   +--- readme.txt
|   +--- version.info
+--- c9800-img-17-3-4
|   +--- ap1g4
|   +--- ap1g5
|   +--- ap1g6
|   +--- ap1g6a
|   +--- ap1g7
|   +--- ap1g8
|   +--- ap3g3
|   +--- readme.txt
|   +--- version.info
+--- c9800-img-17-5-1
|   +--- ap1g4
|   +--- ap1g5
|   +--- ap1g6
|   +--- ap1g6a
|   +--- ap1g7
|   +--- ap1g8
|   +--- ap3g3
|   +--- readme.txt
|   +--- version.info
Xin Lei
多谢分享文章~
scyuen75
EWC-AP in Recovery Mode......
Please use 'archive download-sw' to upgrade AP and Controller image.
@dawnccier @yanfboy
大家好,我也有这个问题,也找到方发解决了,我是把9120u-boot重新安装出厂系统把所有image删掉,可能帮到大家,下面网址可以下载出厂系统和安装方法
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9120axi-access-point/217537-repairing-c9120-c9115-access-points-from.html
yanfboy
@scyuen75 搞定了,非常感谢。
matthewsun
##- 我在C9130上测试了一下,u-boot里面没有boardinit 命令,版本是124 -##
Matthew Sun
NETWORK GENIUS (HK) LIMITED
Unit 2018, Shatin Galleria, 18-24 Shan Mei Street,
Fotan, New Territories, Hong Kong.
TEL: +852 2398 2218
FAX: +852 2398 2228
scyuen75
@matthewsun
这个回复出厂image 只适用于9115/9120, 9130也好像没有官方回复方法
9130 u-boot 指令集有什么?
也有人试过用非官方方法, "rcvr" 回复
rcvr - rcvr - Start recovery process (with TFTP server)
boardinit- Downlod and execute board initialization script
https://community.cisco.com/t5/wireless/lets-figure-out-the-u-boot-flash-procedure-together-tac-unlocked/td-p/4447493
matthewsun
没有rcvr, 也没有boardinit
U-Boot REL 2016.01 (btldr release 287) (Aug 31 2020 - 13:27:04 -0700)
arm-openwrt-linux-gnueabi-gcc (OpenWrt GCC 5.3.0 r48430) 5.3.0
GNU ld (GNU Binutils) 2.25.1
(BTLDR) #
? - alias for 'help'
aq_load_fw- LOAD aq-fw-binary
aq_phy_restart- Restart Aquantia phy
base - print or set address offset
bdinfo - print Board Info structure
bootipq - bootipq from flash device
bootm - boot application image from memory
cmp - memory compare
cp - memory copy
crc32 - checksum calculation
dcache - enable or disable data cache
dm - Driver model low level access
dump_emserial- Dump EM unique serial number
echo - echo args to console
editenv - edit environment variable
em - Expansion module commands
env - environment handling commands
erase - erase FLASH memory
exectzt - execute TZT
exit - exit script
false - do nothing, unsuccessfully
fatinfo - print information about filesystem
fatload - load binary file from a dos filesystem
fatls - list files in a directory (default /)
fatsize - determine a file's size
fdt - flattened device tree utility commands
fipsalgval- run algorithm validation on test vector binary in memory,
default:2000000 (0x02000000)
flash - flash part_name
flash part_name load_addr file_size
flasherase- flerase part_name
flinfo - print FLASH memory information
fuseipq - fuse QFPROM registers from memory
help - print command description/usage
i2c - I2C sub-system
icache - enable or disable instruction cache
imxtract- extract a part of a multi-image
ipq_mdio- IPQ mdio utility commands
is_sec_boot_enabled- check secure boot fuse is enabled or not
itest - return true/false on integer compare
ledstate- Set Led State
loadb - load binary file over serial line (kermit mode)
loadx - load binary file over serial line (xmodem mode)
loady - load binary file over serial line (ymodem mode)
loop - infinite loop on address range
md - memory display
mdio - MDIO utility commands
mii - MII utility commands
mm - memory modify (auto-incrementing address)
mtdparts- define flash/nand partitions
mtest - simple RAM read/write test
mw - memory write (fill)
nand - NAND sub-system
nm - memory modify (constant address)
part - disk partition related commands
pci - list and access PCI Configuration Space
ping - send ICMP ECHO_REQUEST to network host
printenv- print environment variables
printmanuinfoenv- Print manufacture information from memory
printmfgenv- Print manufacture information data
printshenv- printshenv- print shared environment variables
prog_emcookie- Download and program EM cookie
prog_emeeprom- Program EM EEPROM with raw binary data
prog_emserial- Program EM unique serial number
protect - enable or disable FLASH write protection
reset - Perform RESET of the CPU
run - run commands in an environment variable
runmulticore- Enable and schedule secondary cores
saveenv - save environment variables to persistent storage
savemanuinfoenv- Save manufacture information from memory to flash
saveshenv- saveshenv - save shared environment variables to persistent
storage
secure_authenticate- authenticate the signed image
setenv - set environment variables
setexpr - set environment variable as the result of eval expression
setmanuinfoenv- Set manufacture information to memory
setshenv- setshenv - set shared environment variables
sf - SPI flash sub-system
showvar - print local hushshell variables
sleep - delay execution for some time
smeminfo- print SMEM FLASH information
source - run script from memory
tca642x - tca642x gpio access
test - minimal test like /bin/sh
tftpboot- boot image via network using TFTP protocol
tftpput - TFTP put command, for uploading files to a server
true - do nothing, successfully
uart - UART sub-system
ubi - ubi commands
ubifsload- load file from an UBIFS filesystem
ubifsls - list files in a directory
ubifsmount- mount UBIFS volume
ubifsumount- unmount UBIFS volume
usb - USB sub-system
verify_bl- Cisco Bootloader signature verify
verify_lx- Cisco Image signature verify
version - print monitor, compiler and linker version
scyuen75
@matthewsun
" arm-openwrt-linux-gnueabi-gcc (OpenWrt GCC 5.3.0 r48430) 5.3.0 "
不应该有"OpenWrt"吧,会不会已经刷了非思科的imageu-boot, 是就么烦了, 不知道还是不是保修范围,不知道Cisco TAC Team会不会处理
matthewsun
没有,目前正常的系统是一個9800ewc 17.6.1
入门指南
使用上面的搜索栏输入关键字、短语或问题,搜索问题的答案。
快捷链接
