取消
显示结果
搜索替代
您的意思是:
查看次数
28
有帮助
17
评论
zhaowang
WLC的很多配置可能用户不知道是什么意思的情况下不敢改默认配置,但是默认配置一般都是最保守的,性能并非最优,对于新部署的网络,可以参考以下最佳实践文档来配置。当然对于已有网络,也可以做些优化:
http://www.cisco.com/web/CN/products/products_netsol/wireless/pdf/cco_whitepaper_1501_v8.pdf
举个例子:
禁用低数据速率(5GHz 频段和 2.4GHz):
(Cisco Controller) >config 802.11a disable network
(Cisco Controller) >config 802.11a 11nSupport enable
(Cisco Controller) >config 802.11a rate disabled 6
(Cisco Controller) >config 802.11a rate disabled 9
(Cisco Controller) >config 802.11a rate disabled 12
(Cisco Controller) >config 802.11a rate disabled 18
(Cisco Controller) >config 802.11a rate mandatory 24
(Cisco Controller) >config 802.11a rate supported 36
(Cisco Controller) >config 802.11a rate supported 48
(Cisco Controller) >config 802.11a rate supported 54
(Cisco Controller) >config 802.11a enable network
(Cisco Controller) >config 802.11b disable network
(Cisco Controller) >config 802.11b 11gSupport enable
(Cisco Controller) >config 802.11b 11nSupport enable
(Cisco Controller) >config 802.11b rate disabled 1
(Cisco Controller) >config 802.11b rate disabled 2
(Cisco Controller) >config 802.11b rate disabled 5.5
(Cisco Controller) >config 802.11b rate disabled 11
(Cisco Controller) >config 802.11b rate disabled 6
(Cisco Controller) >config 802.11b rate disabled 9
(Cisco Controller) >config 802.11b rate supported 12
(Cisco Controller) >config 802.11b rate supported 18
(Cisco Controller) >config 802.11b rate mandatory 24
(Cisco Controller) >config 802.11b rate supported 36
(Cisco Controller) >config 802.11b rate supported 48
(Cisco Controller) >config 802.11b rate supported 54
(Cisco Controller) >config 802.11b enable network
评论
ctrler
Community Member
工控数据中心要用到这些东西,先学习,感谢!
stepwise-kevin
頂~~ 感謝分享!!
入门指南
使用上面的搜索栏输入关键字、短语或问题,搜索问题的答案。
快捷链接
