取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
思科无线AP无法上线,求解答。
zhanglong128
AP的型号是AIR-AP1832I-H-K9   版本8.3.112.0  和 WLC一致  但是最近出现无法上线的问题,并且会自动重启。
其他的同型号版本的AP可正常上线。
3 条回复3
ilay
感觉可能是个bug,现象很类似,可能的话换个版本试试
Apr 15 06:26:18 kernel: [*04/15/2021 06:26:18.3468] This AP model is supported by controller version newer than 7.0.0.0!
Apr 15 06:26:18 kernel: [*04/15/2021 06:26:18.3468] Discovery response from MWAR ''running version 0.0.0.0 is rejected.
Apr 15 06:26:18 kernel: [*04/15/2021 06:26:18.3468] Failed to decode discovery response.
Apr 15 06:26:18 kernel: [*04/15/2021 06:26:18.3468] CAPWAP SM handler: Failed to process message type 2 state 2.
Apr 15 06:26:18 kernel: [*04/15/2021 06:26:18.3468] Failed to handle capwap control message from controller - status 4
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvf71074/?rfs=iqvred
Rockyw
WLC的日志也提供一下吧。看看下面的文档有没有帮助
思科室外AP无法注册到WLC
https://www.cnblogs.com/MomentsLee/p/9992991.html
CAPWAP - Failed to decode discovery response
https://community.cisco.com/t5/wireless/capwap-failed-to-decode-discovery-response/td-p/4084985
Cisco AIR-AP2802I-E-K9 Failing to Join Controller
https://community.cisco.com/t5/wireless/cisco-air-ap2802i-e-k9-failing-to-join-controller/td-p/3870309
Troubleshoot AP Joining Issues – Cisco Mobility Express
https://packet6.com/troubleshoot-ap-joining-issues-cisco-mobility-express/
Rockyw | If it solves your problem, please mark as answer. Thanks !
sn270043685
这个是AP射频坏了,需要维修的,如果想修可以联系我yfsnnui520
快捷链接
